Will 305's fit on a stock Dodge Ram 1500?
Old May 13, 2009 | 04:33 PM
zje400ex's Avatar
zje400ex
Question Will 305's fit on a stock Dodge Ram 1500?
Hey, I'm picking up a set of mickey thompson atz tires on saturday that are 305 65 17 with dc-1 wheels. Will they fit on my stock 1997 dodge ram 1500 4x4 or do i need to buy a leveling kit or a 3" lift kit
Old May 13, 2009 | 06:51 PM
Bdodge60's Avatar
Bdodge60
Im pretty sure they will not fit stock. I have 315s with a 3 inch body lift and they rub so you will need at least 2 inches of lift.
Old May 13, 2009 | 07:30 PM
olyelr's Avatar
olyelr
Mainly depends on the wheel width and backspacing, but either way you will most likely rub.
If they are 17x9 wheels it will most likely rub. If you were puting 33x12.5's on the stock rims you would have a chance, but I doubt it with the Cepeks.
Old May 13, 2009 | 07:54 PM
zje400ex's Avatar
zje400ex
They are 17x9 dick cepek dc-1's with 305 65 17 mickey thompson atz's. I'm thinking about buying the 3" lift kit from topgunzcustoms or a 2" coil spacer and 2" rear blocks or add-a-leafs. Would i be fine with either of these lifts?
Old May 13, 2009 | 08:59 PM
dsertdog56's Avatar
dsertdog56
You might scrape by (pun intended) with the 2 inch, but if the 3 inch lift comes with slightly longer arms, it would be better choice. The longer arms will move your axle forward so that the factory caster and suspesion arc will be maintained.
Old May 13, 2009 | 09:47 PM
zje400ex's Avatar
zje400ex
I'm thinking about buying this...
http://cgi.ebay.com/ebaymotors/3-Dod...Q5fAccessories
Old May 13, 2009 | 09:50 PM
zje400ex's Avatar
zje400ex
Would a 3" spacer and 1.5" block be enough to clear the 305's? I've researched online and saw a few dodge rams with a 2.5" spacer and add-a-leafs that clear 305's. I think i'll order this kit this weekend.
Old May 13, 2009 | 10:20 PM
olyelr's Avatar
olyelr
Yep, that sounds like a perfect setup to me.
Old May 14, 2009 | 12:37 AM
zje400ex's Avatar
zje400ex
Ok. thanks for the help. i'll post pictures in a few weeks when i get my lift installed
Old May 16, 2009 | 04:56 PM
zje400ex's Avatar
zje400ex
i just ordered a rough country 2.5" coil spacer and rough country 2" blocks. i'm gonna have to buy new shocks so if anyone has a set laying around or know where i can find a good deal that'd be nice.
