Trans Fluid and Front Gear Ratio ?
Old Jun 7, 2009 | 10:44 PM
Relex's Avatar
Relex
Default Trans Fluid and Front Gear Ratio ?
My friend is going to get a front locker for his truck but isn't sure of the gearing. He has an 01 1500 5.9 4x4.
Next..
What trans fluid should I use for my trans and how much do I need to put in? I was out playing today and ended up going though some stuff that didn't look that bad but really was.
Photo06071850.jpg?t=1244428991
0607091910-00.jpg?t=1244429026
Old Jun 7, 2009 | 10:47 PM
Laramie1997's Avatar
Laramie1997
The best way to know what gear ratio your friend's truck has would be to go to a dealership and have a build sheet printed out.
Options were: 3.21:1, 3.55:1, 3.92:1, and 4.10:1 (only in the off road edition)
As for the transmission fluid you need to use ATF+4 and only that.
Old Jun 7, 2009 | 11:06 PM
Relex's Avatar
Relex
Thanks, how much trans fluid would i need?
Old Jun 7, 2009 | 11:07 PM
Laramie1997
I wanna say its like 6 quarts or something close to that. It should be listed in your service manual on the back side of the book.
Old Jun 7, 2009 | 11:13 PM
PurplDodge's Avatar
PurplDodge
No, its in the front of the service manual!
Do you have an external filter, or cooler? I would say to get 6 to be sure. Also, put a drain plug in.
Old Jun 7, 2009 | 11:21 PM
Laramie1997
purpl, on my 97 its on the back. That's why I said it.
Relex's Avatar
Relex
I don't have a clue if I have an external cooler or filter. Wasn't there a DYI somewhere here for changing trans fluid and installing a drain plug? As for the trans fluid sounds like I'll need to get 7, 6 for filling it back up then 1 for flushing.
Old Jun 8, 2009 | 12:51 AM
jasonw's Avatar
jasonw
Site Moderator
Amsoil transmission fluid, from what I've heard, would be OK as well.
But nothing else, either ATF+4 or Amsoil.
Old Jun 8, 2009 | 06:27 AM
MonteC's Avatar
MonteC
I concur.
Old Jun 8, 2009 | 07:58 AM
aim4squirrels's Avatar
aim4squirrels
Jack up the rear end of the truck and put it in neutral.
Put a mark on the bottom of one rear tire and on the bottom of the rear drive shaft. count how many times the drive shaft spins around as opposed to 1 revolution of the tire.
If it went 3.5 times around you have 3.55 gears
just under 4 times 3.92 gears
just past 4 times 4.10 gears
etc, etc.
