New round aircleaner!
#43
mine was under 40 for the round filter, then add in a breather for the crankcase, piece of 1/4-20 (i think) all thread for the S-Bolt, and a 1/2 inch spacer (if you go the Edelbrock Pro-Flo like i did) number 1221, i believe, correct me if im wrong
i also put a new gasket in between the spacer, and TB, its like 1.99 for it, id replace it, b/c most likely its about shot (mine fell apart when i took the airbox off)
Cereal, where did you get that sticker, i want one that says 318 instead of 360 for obvious reasons :P
#44
#45
#46
#47
no clue, but you don't see the s bolt, its hidden within the air cleaner
it took all of 10 minutes to make mine, a grinder is a much quicker way to trim it than hacksaw, and i found chasing the thread with a die is a good idea, to make installation on the TB easier
just be careful if you use a grinder, although the sparks are pretty, they can injure unprotected eyes, and the s bolt will get hot when you cut it
#48
#49
Oh I know it isn't hard to do at all. I was just thinking of a lazy way to do it. i am sure it wouldn't take but a minute or two to fab the rod but I am kind of **** when it comes to the little things that stick out at some point when I get the infamous "why did you do that" question from someone with less ambition than me.
#50
on
i used bolt cutters to cut my s bolt and i put four nuts on each end and used 2 big cresent wrenches to bend it. its 1/4 20 threads btw.
and mine is the mr. gasket 1480.
