whoops
Old Jun 22, 2009 | 02:35 PM
dodge15004x45.9's Avatar
dodge15004x45.9
Its ok I over filled my truck with oil. Now I have a leak coming from the timing chain cover.
Old Jun 22, 2009 | 02:59 PM
PurplDodge's Avatar
PurplDodge
How do you over-fill an engine that takes a straight 5 quarts!??
Old Jun 22, 2009 | 03:14 PM
dodge15004x45.9
Well I put 4 and change in. I was doing it at the fire house than we had a call so went on the call and for got how much I put in. Add a gt of the engine restore. So I noticed I had a leak. pulled the dip stick and was like holy CHIT! It at least 1qt over. I got a leak coming form the timing cover. So tomorrow I'm going to drain some of the oil out and try to tight up the bolt and hope that takes care of the leak. If not I need a new timing cover gasket. Or some gum. JP!
Old Jun 22, 2009 | 03:58 PM
wjxavier's Avatar
wjxavier
i always put 5 quarts in my engine as well, but its still a little over the max mark, nothing i'm too worried about but it's still more than it needs.
Old Jun 22, 2009 | 04:12 PM
BigRedRam95's Avatar
BigRedRam95
mine takes 6 quarts because I have a bigger oil filter
Old Jun 22, 2009 | 04:21 PM
PurplDodge's Avatar
PurplDodge
I have the bigger oil filter and it still takes 5 quarts.
Old Jun 22, 2009 | 04:47 PM
BigRedRam95
I put in 5 quarts first and it was low so I put in 6 and I was a little high so next oil change I will put in 5 1/2 quarts.
Old Jun 23, 2009 | 11:06 AM
Sheriff420's Avatar
Sheriff420
thats why its good to get oil from walmart, it comes in a 5 qt jug. i never understood why the parts stores have gallons instead of 5 qt jugs. most vehicles take 4.5-5 quarts, it just makes sense.
Old Jun 23, 2009 | 12:21 PM
charlie1935's Avatar
charlie1935
I use the big filter on both my 96 & 87. The 96 takes 5 1/2 and the 87 takes 6 1/2 quarts.
