Play in the steering column
Old Jun 22, 2009 | 10:24 PM
mjackson92rs's Avatar
mjackson92rs
Default Play in the steering column
After much inspection I have concluded that the majority of the play in my steering shaft is coming from above the intermediate shaft where it connects to the steering column. I can clearly see a pretty fair amount of play in the shaft at this point. My question is have any of you guys ran into this problem? Recommendations?
The play is coming from where the arrow is pointing to, after the Rock Solid Ram Steering bushing pictured. (I took the pic from rock solid ram steering's website.)
Old Jun 23, 2009 | 05:23 AM
zman17's Avatar
zman17
Retired Moderator - RIP
IIRC , after the new bushing is installed it seats the rest of the steering column bearings/bushings. I had major play up by the wheel and thought that was the prob. Turns out that after installing the RSRB all the play was gone.
Old Jun 23, 2009 | 09:58 AM
Aubrey's Avatar
Aubrey
There's a bearing in there that wears out and causes slop.
Old Jun 23, 2009 | 04:27 PM
zman17's Avatar
zman17
Yes, but I believe they are cone shaped. And when it has the right pressure on it, it fully seats like the upper one.
Old Jun 23, 2009 | 11:25 PM
mjackson92rs
great. i have the RSRB on its way. zman, did you find that the RSRB helped your steering out a lot? I currently have a lot of play in my wheel and am hoping this is the fix. Thanks.
Old Jun 23, 2009 | 11:38 PM
BigDodge99's Avatar
BigDodge99
I have had the same trouble and the bushing did not help my situation.
Old Jun 23, 2009 | 11:39 PM
mjackson92rs
Did you find a fix to your problem?
Old Jun 24, 2009 | 05:22 AM
zman17's Avatar
zman17
It doesn't fix the left to right play, you have to check out the rest of the steering components. Intermediate shaft, gear box, tie rods etc....
Old Jun 24, 2009 | 11:51 PM
BigDodge99's Avatar
BigDodge99
No I havent. My truck has been sitting since early fall last year for a 408 build. All my steering is new up to the column including ball joints.
Old Mar 2, 2014 | 11:24 AM
CoryVolkenant's Avatar
CoryVolkenant
Default same issure any body ever find a fix?
i have the same issue any one ever find a fix?
