Im having ruff idling problem now
Old Jun 25, 2009 | 06:59 PM
dodgeram2001's Avatar
dodgeram2001
Exclamation Im having ruff idling problem now
well its now ruff idling an shop says it;s cylinder number 5 so any ideas ?
Old Jun 25, 2009 | 07:24 PM
VOATMJ1's Avatar
VOATMJ1
Yep, it's probably what they said. Is your CEL on? I had this same problem, CEL was on, engine running rough and the dealer did a compression test and told me it was cylinder #3 and that the head was probably cracked. Well it turned out that the cylinder was not cracked but burnt, but the cylinder still had to be replaced. Lucky for me, I had an extended warranty in place. Trucks runs great now. Of course as soon as the turck was fixed, a week later my dealer got thier Dodge dealership yanked by Chrsyler, as they were on the hit list of dealership closings. Now my nearest Dodge dealer is 20+ miles away vs. the 5 miles I drove to my local dealer.
Old Jun 25, 2009 | 07:30 PM
dodgeram2001
i hope thats not my prob lol they said it just needs plugs an wires so i hope that will fix it . a good tune up hopefully
Old Jun 25, 2009 | 07:53 PM
dodge15004x45.9's Avatar
dodge15004x45.9
Could be a clogged cat.
Old Jun 25, 2009 | 11:08 PM
dodgeram2001
u never know could be .
Old Jun 25, 2009 | 11:13 PM
dodge15004x45.9
Take out the up stream o2 and see if it gets better.
Old Jun 26, 2009 | 01:11 AM
xray99's Avatar
xray99
Did you try replacing your Rough Idle Sensor ?
Just kidding, hope the problem isn't serious.
Old Jun 26, 2009 | 11:25 AM
aim4squirrels's Avatar
aim4squirrels
Cheap wires and a crossfire between the number 5 & 7 cylinders would be my guess. Route the number 5 & 7 wires as far apart as you can.
Clogged cat typically presents first on the 7 or 8 cylinders since they're the furthest back.
Old Jun 26, 2009 | 11:27 AM
aim4squirrels
Double post FTW!
Old Jun 26, 2009 | 12:49 PM
dodgeram2001
The Check Engine Light is not on at all . only light that is on is the Brake light for some reason probably just need to bleed the brakes though.
