check valves for wild vents
Old Jan 8, 2011 | 07:31 PM
  #131
BIGBIRD85's Avatar
BIGBIRD85
i sprayed WD40 into my check alves and PCV valve and stopped my problem with the WILD vents!!
i'm just sayin
Old Jan 25, 2011 | 12:42 AM
  #132
TS6034's Avatar
TS6034
I'm new to this site, but not to Dodge trucks. I worked as a Dodge tech back in 00 to 04. Never really had to deal with the "wild vents" but just recently I've been very annoyed with mine. This thread (site) has great info! I've already tested both my CV's prior to reading this. Tomorrow I'm gunna check my PCV. I've also noticed a long delay in disengaging my 4X4. Seems to go into 4X4 quickly tho...
Oh....my rig is a 99 2500 5.9 4X4 with 221,000 on the clock.
Old Jan 25, 2011 | 06:19 AM
  #133
BIGBIRD85's Avatar
BIGBIRD85
Originally Posted by Sheriff420
does anyone know which direction the vacuum should flow in the lines at the t and on the side of the manifold and which direction should make them close? i replaced the one on the t and the one on the side of the manifold and i still have the wild vents. i have also looked at the wild vent fixes and none of them say which way the valves should go.
EDIT for future people with wacky vents, the part # for the check valves is 4549209
is this dealer only part?
Old Jan 25, 2011 | 07:46 AM
  #134
UnregisteredUser's Avatar
UnregisteredUser
Well, yeah, it is. The generic parts from the auto parts store will work, but you'll have to hillbilly engineer them into place. They're cheap enough at the dealership to make that hillbilly engineering a silly idea.
Old Jan 25, 2011 | 10:26 AM
  #135
Flipzslick's Avatar
Flipzslick
Ok I have looked and looked again, I have a cv right by the in take then a T (4x4,c.c,heater), the line that goes to the vents goes up over the tranny dipstick, then into another T one line goes to the top of the fire wall and on goes in by the ac line, so do I only have the one valve?
Old Jan 25, 2011 | 10:33 AM
  #136
BamaRam97's Avatar
BamaRam97
Your second check valve should be in that last line T. It connects to the line going into the firewall by the AC line. Kind of the bottom of the T is where the check valve is.
Old Jan 25, 2011 | 10:37 AM
  #137
Mine only has the one check valve as well. I think things got shuffled over the years.
Old Apr 4, 2011 | 10:25 PM
  #138
Craig540's Avatar
Craig540
I fixed mine with a autozone universal CV, now to fix the noise I have coming from the middle of the dash. It happens when the brake is pressed at a stop light. The noise got lower when I put the CV valve in. so it must be a vacuum noise.
Any ideas ?
Old Jul 5, 2011 | 03:47 PM
  #139
Mudshack's Avatar
Mudshack
Well, I pulled the check valve off from the connection near the firewall....could blow both ways through it. Then I go and try and pull what I thought was a check valve from the elbow going into the intake and BREAK! The rubber hose gave way. Concequently, after it broke, I blew through the elbow and both ways it was very tough to blow through. So.....I went from having wild vents, to NO vents on a 95-degree day. lol
Old Aug 22, 2012 | 07:55 PM
  #140
redhemi06's Avatar
redhemi06
Default t connector question
so is this the right t connector? if so where is the check valve?
1996 dodge ram 5.2l 4x4 reg cab
