transmission cooling upgrade, need suggestions
Old Jun 26, 2009 | 08:08 PM
szarin's Avatar
szarin
Default transmission cooling upgrade, need suggestions
I am looking to see what some other guys have done, or problems they have over come.
I am looking at ordering a chrysler deep transmission oil pan with the extra hole for temperature sensor, getting a mechanical full sweep autometer transmission gauge. This will allow me to add 2 more quarts, keep an eye on my transmission.
However, i am still looking to add a second transmission cooler, one from B&M, either their 10 or 13" wide super coolers.
My question is, what is the best way to tie the new system in. I have seen guys just cut the rubber hoses add a double barbed coupler and connect it to the new transmission cooler. How much pressure is in those hoses? can a double barbed coupler & a hose clamp keep the pressure under control?
What size of threads are on the 46RE(A-518) if i wanted to get 1/2" steel braided tubing and bypass the rad and go straight into the B&M transmission cooler? or is it best not to screw with the threads on the side of the transmission?
just want to get an idea of what others have done. I am doing this because i am almost done with the 408 upgrade and i dont want to cook the transmission heh.
Old Jun 26, 2009 | 09:10 PM
MonteC's Avatar
MonteC
A barbed fitting and clamps will hold just fine, they are pretty much the industry standard for installing coolers in transmission shops.
Although a steel braided line would look MUCH better. I dont know the size of the threads, i would guess to say they are just NPT, but ive never taken the time to measure the threads.
Old Jun 26, 2009 | 11:02 PM
BigRedRam95's Avatar
BigRedRam95
Don't know if you want to see these but hear is a pic of my engine oil cooler
and hear is a pic of my trans cooler
Old Jun 26, 2009 | 11:21 PM
dodge15004x45.9's Avatar
dodge15004x45.9
I want to get one with a fan on it. Over kill I know. But when off road and doing a lot of slow moving it can't hurt.
Old Jun 27, 2009 | 12:59 AM
Sheriff420's Avatar
Sheriff420
heres mine. it keeps the fluid between 160º and 170º. its connected with hose clamps also. i was told by the guy that rebuilt my transmission that the factory coolers tend to have the material that lines the inside break up and clog things up in the tranny.
Old Jun 27, 2009 | 01:19 AM
dhvaughan's Avatar
dhvaughan
there's not much pressure. all you need is rubber transmission hose and clamps. you don't even need barbed fittings. just cut the end of the original tubing and clamp on the hose. remove the check valve. you can double clamp it if it makes you feel better.
https://dodgeforum.com/forum/2nd-gen...ter-added.html
word of caution on oversize pans - the same pan SHAPE fits the 727, 518, 46rh, 46re, etc. the 46re is already extra deep to accomodate the solenoids. you can measure it, but its several inches deep. the stock 727 is shallow. so - pans advertised as 727 extra deep may be the same or more shallow that stock 46re. so beware. also beware the magtec 727D and 727DD are two different things. and summit has one that won't even fit a 46re.
Old Jun 27, 2009 | 10:24 AM
MonteC's Avatar
MonteC
If you use a non barbed line, use double clamps, a single clamp will leak. Barbed lines will guarantee no leaks.
Old Jun 27, 2009 | 10:28 AM
Gary-L's Avatar
Gary-L
Veteran: Navy
I want to install a transmission cooler as well, but don't like how the A/C condenser is stacked in front of the radiator and then the trans cooler is stacked atop that. Not a slight against you, it's how 99% of the installs are done.
A friend of mine showed me his 2006 Ram recently, and I like how the radiator is on one side of the front end and the A/C condenser is on the other.
I would like to install the cooler in a different location that will still be effective.
Old Jun 27, 2009 | 01:25 PM
Ram15002ndGen's Avatar
Ram15002ndGen
You must be talking about the 3rd gens. They have this split set up you're talking about (the last time I saw one). If you don't want to set it up like Sheriff did, just set it up in the corner in the front, there is plenty of room. If you mean you don't want to attach it to the condenser then just make some brackets and mount it off the body rail that runs along there.
BTW didn't any of your trucks come with a tranny cooler? Mine has a tranny cooler factory installed between the condenser and the radiator. First the lines go into the radiator, then out to the cooler, then back to the tranny. I would think that would be good enough.
Old Jun 27, 2009 | 04:28 PM
Acapalic's Avatar
Acapalic
^^ the post above mine , there is alot of room on the side of the radator/ condesnor, Im planning on putting my engine oil and tranny coolers on ethier side.
