m1 or hughes intake
Old Jun 30, 2009 | 03:38 PM
Salex007's Avatar
Salex007
Default m1 or hughes intake
so my question is which one has the smaller height? I have the 5.9 in a 96 ram
Old Jun 30, 2009 | 04:32 PM
zman17's Avatar
zman17
Retired Moderator - RIP
I believe they are the same height.
Old Jun 30, 2009 | 05:32 PM
BlueBeast2's Avatar
BlueBeast2
The M1 is for a more high performance motor. If you have a stock or slightly modded motor go with the Hughes. The M1 will make you lose some low end so I've heard
Old Jun 30, 2009 | 07:52 PM
mikey0469's Avatar
mikey0469
the m1 and the hughes intake are the same height.
Old Jun 30, 2009 | 07:57 PM
jasonw's Avatar
jasonw
Site Moderator
The M1 is supposed to be for racing engines, so its primary power is supposedly in the upper RPMs that you most likely will not see.
The Hughes is supposed to be a much better bet, especially for low end, although I admit I have no personal experience with either, just what I've read and heard.
Old Jun 30, 2009 | 10:03 PM
Salex007's Avatar
Salex007
ok revised sorry, are both of these intakes shorter than the stock intake or not?
Old Jun 30, 2009 | 10:46 PM
acsamples79's Avatar
acsamples79
i believe my hughes sits the same height as my stock
Old Jun 30, 2009 | 11:06 PM
Salex007's Avatar
Salex007
ok hughes sounds good, but anyone chime in on the m1?
Old Jun 30, 2009 | 11:23 PM
lastrights's Avatar
lastrights
there 2 guys on here that have the airgap and love it, m1 is for like a 408 stroker
Old Jul 1, 2009 | 08:41 AM
aim4squirrels's Avatar
aim4squirrels
They are all the same height. They have to be to keep the linkage connections and bracket on the TB from interfering with other parts on the engine.
Not sure why you're trying to save height inside, but you're going about it in the wrong way. If you need more height, a body lift will give it to you, or if you're running the round air filter, go smaller.
