uh oh
#71
the end of one of the grease caps of the u-joint is tapped with an odd thread.
because of the low clearance, you can't put a permanent zerk in it. i tried to use a temporary zerk, to install only for greasing, but i tried every zerk i could find, and none had the proper threads.
this little grease adapter did have the right threads. i put it on only to grease those front u-joints, and then remove it and store it. unless you spend a lot of time cleaning it, it remains full of grease.
yes, the black rubber plugs just cover the threads, and keeps it clean.
#72
another post regarding the adapter is pasted below.
i found that if you permanently screw in a zerk to the adapter, its less of a pain to use this.
i also recommend the Precision brand Super Strength greaseable. The front axle is part #377 and the drives shafts front and rear are i think #270. Rockauto website and Advance and Oreilly will all point you to the right numbers.
however - note that the Super Strength has a grease port in the cap, not in the cross - and there is NO ZERK in the cap, only a plug... so you must purchase a grease adapter, and a ZERK with a 3/8 NPT thread to make your own grease adapter.
you remove the plug (don't lose it). screw in your adapter. grease it. remove the adapter. reinstall the plug. its a little bit of a pain, but when you see the mass of the cross you say - good god what a u-joint.
adapter part number, from Advance or any parts store for a couple bucks: MTN2500-SOA (2500 is numeric, SOA is alphabetic)
#73
on
I just screwed it onto an old, small grease gun that I had. I used that crimson grease because it's supposed to be more tacky and less prone to leaking out since it's a little thicker than normal grease.
I got it all back together and when I was tightening one of the hub bolts I pushed on the tie rod end with the handle of the ratchet and noticed that I need to replace some suspension components. I also noticed a bit of a coolant leak.
So sometime in the near future I need tie rods, I need to fix a leak, I need to get a wiring harness for my headlights and I need to try to adjust one of the headlights so the beam won't be star-gazing any more.
This truck sure does like attention.
