Lockouts
Old Jul 26, 2009 | 09:03 PM
Dr Donut's Avatar
Dr Donut
Default Lockouts
I have a 2001 ram 4x4 standard cab short box and wanted to change the hubs to manuals over the autolocks looking for any ideas on how to do this cheaper is better but not the most important
Old Jul 26, 2009 | 09:18 PM
busaguy05's Avatar
busaguy05
Here's a link to the conversion kit http://emsoffroad.com/shop/index.php...4fb3b4036fafcd Pricey but it's the only kit I found for our trucks, at that they only have them for non abs axles. They list the ones with abs but I have contacted them about it and they have not been realest yet.
Old Jul 26, 2009 | 09:37 PM
Dr Donut's Avatar
Dr Donut
I saw those kits but that is a lot more than i'd like to spend. The actuator for my front axle went out and i would like to just junk the whole system. I've been told you can replace just the hubs and found a few parts on summit that claim to fit. I was hoping someone out there has already tried this and could offer some insight.
Also I found this kit http://www.summitracing.com/parts/PO...UP&prefilter=1 but I'm not sure if it would replace the stock one or if it is an addition to the stock system
Old Jul 27, 2009 | 12:52 AM
dhvaughan's Avatar
dhvaughan
posi-lok is the answer. its a manual cable that you engage from the comfort of the cab. damn climbing out into the middle of the mudhole. also just by the way, most cad problems are either broken vac lines or sticky/rusty shaft inside the cad.
(edit - and can be repaired if you care to fix the damn thing. i didn't either)
http://www.4x4posi-lok.com/
Old Jul 27, 2009 | 01:03 AM
dodge15004x45.9's Avatar
dodge15004x45.9
I 2nd tht!!! I'm not getting out to lockem up!
Old Jul 27, 2009 | 01:37 AM
95MaroonMonster's Avatar
95MaroonMonster
getting out to lock them is a pain, but soo classic 4x4, lock the hubs, throw er in 4x and drop that hammer
Old Jul 27, 2009 | 12:09 PM
Dr Donut's Avatar
Dr Donut
I think ill end up using the 4x4 posi lock but I think ill try cleaning the part first just to make sure theres no other problems lol thanks for help guys
Old Jul 27, 2009 | 03:49 PM
Miami_Son's Avatar
Miami_Son
Originally Posted by busaguy05
Here's a link to the conversion kit http://emsoffroad.com/shop/index.php...4fb3b4036fafcd Pricey but it's the only kit I found for our trucks.
There is another kit, but just as expensive.
http://www.dynatrac.com/products_freespin_dodge.html
Old Jul 27, 2009 | 06:07 PM
dhvaughan's Avatar
dhvaughan
here you go. be aware that the vac switch on top of the t-case is the brain behind this stupid thing and it puts vac on one line for 2wd and vac on the other for 4wd. then the vac diaphram slides the coupling collar one way or the other to couple/uncouple the axle halves. when you remove the cad cover you'll see the collar, and you can slide it back and forth by hand. you can also operate the t-case and with vac hooked up see the diaphram slide the fork back and forth. stuck/rusty diaphram shaft inside the cad is a common problem.
from the service manual.
http://www.dodgeram.org/tech/repair/..._engagment.htm
Old Jul 27, 2009 | 06:51 PM
Dr Donut's Avatar
Dr Donut
Thanks for the awesome link very nice to see something before you tear it apart for once. Hopefully I can just clean it and save some money for other mods.
