What's wrong with this picture?
Old Jul 27, 2009 | 09:39 PM
xray99's Avatar
xray99
Yes, a cotter pin will most definetly do the trick.
Old Jul 27, 2009 | 10:36 PM
tiggamonsta's Avatar
tiggamonsta
The factory clip is just a piece of plastic that snaps into the linkage and then the tip of that rod snaps into it. In a pinch you could just pop the rod through the linkage and wrap bailing wire around it, so you could drive it.
Old Jul 27, 2009 | 10:53 PM
Ram15002ndGen's Avatar
Ram15002ndGen
Don't forget the Duct Tape! No home repair is ever complete without Duct Tape.
Old Jul 28, 2009 | 07:37 AM
zman17's Avatar
zman17
Retired Moderator - RIP
Go to your local parts stores and see if any of them have a pack of this part# 14041 in the HELP! section.
Old Jul 28, 2009 | 11:12 AM
Sheriff420's Avatar
Sheriff420
quick clip ~> http://www.bicwarehouse.com/hitch-pi...-p7928zbu.html
Old Jul 28, 2009 | 11:41 AM
zman17's Avatar
zman17
Using a clip or cotter pin temporarily is fine, but if you don't replace it with the OEM bushing, the shaft and the hole , will soon start to wear and then you'll be replacing the linkage instead of a 2 dollar part.
Old Jul 28, 2009 | 11:58 AM
zman17's Avatar
zman17
https://www.dormanproducts.com/cgi-b...rid=0x003110b4
Click on detailed applications
Old Jul 28, 2009 | 01:46 PM
xray99's Avatar
xray99
Have had a cotter on mine for 7 years with no problems, maybe I'm just lucky.
Old Jul 28, 2009 | 02:03 PM
zman17's Avatar
zman17
Awesome. You've had it for that long. I'm surprised actually. Until the day it's warn enough and you park on an incline and it's only part way in park because of the wear and jumps out of park and rolls . Do you have saw dust in the rear end and duct tape on the brake lines too?
Old Jul 28, 2009 | 02:53 PM
xray99's Avatar
xray99
Well, apparently the originals are prone to failure too, or I wouldn't have had a cotter pin, and the OP would not have his linkage dangling at the moment.
