unkown leak??
Old Jul 28, 2009 | 01:34 PM
MattBiz223's Avatar
MattBiz223
Default unkown leak??
so i seem to have what looks like a differential fluid leak because the piece is connected to the front axle but idk for sure, has anyone had this before and know what it takes to fix it?
Old Jul 28, 2009 | 03:15 PM
Mark Benson's Avatar
Mark Benson
Just looks like the axle disconnect actuator needs to be resealed.
Old Jul 28, 2009 | 05:50 PM
95MaroonMonster's Avatar
95MaroonMonster
x2, reseal and you'll be good to go
Old Jul 28, 2009 | 06:50 PM
dhvaughan's Avatar
dhvaughan
remove the 4 bolts and hope they don't break, or aren't already broke. a small puddle of diff fluid will run out. if the gasket is original its a funky, cork/metal thing. discard it.
inspect fork, collar, axle ends, etc.
clean both surfaces. use rtv for gasket. reinstall, making sure collar and fork line up.
torque bolts to whatever they are supposed to be which is not a whole lot, maybe 15 lbs or so.
Old Jul 29, 2009 | 01:13 AM
MattBiz223's Avatar
MattBiz223
okay thanks guys
Old Jul 29, 2009 | 01:28 PM
Sheriff420's Avatar
Sheriff420
96 in. lbs. haynes calls it "shift motor housing"
don't forget to check your diff fluid after you seal it up.
Old Jul 29, 2009 | 01:41 PM
zman17's Avatar
zman17
Retired Moderator - RIP
It is also recommended that after you bolt the housing back on and before you put the vent hose back on, put a few squirts of rear end grease in it.
Old Jul 29, 2009 | 02:05 PM
Sheriff420's Avatar
Sheriff420
haynes says to take the indicator switch out (where the wire is plugged in) and squirt 5oz. of diff fluid in there after its bolted back on. i just reinstalled mine the other day, the indicator switch has a pretty low torque on it (maybe 10'lbs) so it's easy to take off.
