2001 dodge ram 1500
Old Jul 29, 2009 | 07:36 AM
rambo01's Avatar
rambo01
Default 2001 dodge ram 1500
My son has 01 1500 with problem. When started in morning, it will turn over and run for about 3 minuets, then it bogs down and ideling rough and wanting to stall. when doing this, you hear a loud sucking of air coming from cold air intake i presume. does this for about 3 more minuets, calms down then runs fine until next morning when starting, only does it on cold start. We have replace map sensor and new iac. what else could be the problem? Mechanic is stumped.
it is 2001 dodge ram 1500 quad
5.9 engine
any help would be greatly appreciated
thanks
Old Jul 29, 2009 | 11:26 AM
zman17's Avatar
zman17
Retired Moderator - RIP
The IAC might be a defect. And did the throttle body bore where the IAC installs into get cleaned? Also test the TPS.
Old Jul 29, 2009 | 11:29 AM
Twisted Metal's Avatar
Twisted Metal
IIRC, someone described a similar problem, and it was the front 02 Sensor. Seems it was only occurring as the engine was warming up, before it went closed loop.
Old Jul 29, 2009 | 11:46 AM
zman17's Avatar
zman17
Bravo, I do believe you are correct sir. I also read that thread, and there was no cel either.
Old Jul 29, 2009 | 08:10 PM
jasonw's Avatar
jasonw
Site Moderator
I'm not necessarily disagreeing with you as I do not recall that thread, but I don't see how this would be possible.
Closed loop is where the truck listens to the O2 sensor. Before that, during "warm up" (open loop), it ignores the sensor. Why would changing the sensor affect the warm up period when it doesn't listen to the sensor?
Old Jul 29, 2009 | 08:25 PM
dhvaughan's Avatar
dhvaughan
he said it runs ok for about 3 minutes, then runs rough.
could it warm up enough in 3 minutes to get to closed loop ?
Old Jul 29, 2009 | 08:27 PM
jasonw's Avatar
jasonw
Site Moderator
Mine does it in 4-6 minutes. Timed it back when I had the Superchips issue, where it would hesitate/stumble in open loop but not in closed loop.
Old Jul 30, 2009 | 07:04 AM
rambo01's Avatar
rambo01
so everybody is thinking 02 sensor. even without throwing any codes? even has my mechanic stumped
Old Jul 30, 2009 | 07:38 AM
mikey0469's Avatar
mikey0469
i think its safe to say everyone on here is a mechanic. some probably know more about their ram than any mechanic does...if its a cheap part and its suggested, i would try it.
Old Aug 4, 2009 | 07:30 AM
rambo01's Avatar
rambo01
so today he starts truck and goes to take off and you can hear it bogging down and when trying to give it gas hear a popping noise.
