best place to run wires through the firewall
Old Apr 30, 2010 | 12:24 AM
  #21
yakkier's Avatar
yakkier
fallow the throttle cable, it's a safe spot then tuck the wires up above the clutch and brake pedal.
Old Apr 30, 2010 | 10:12 AM
  #22
Sheriff420's Avatar
Sheriff420
You could just drill a hole and use a rubber grommet to keep the wire from getting cut.
Old Apr 30, 2010 | 10:15 AM
  #23
Maxx_Magnum's Avatar
Maxx_Magnum
I ran my amp wire and switch wires for my rollbar lights through the rubber grommet for either the steering shaft or throttle cable, can't remember off the top of my head now... I just cut a small hole in it and fed them through there
Old Apr 30, 2010 | 10:44 AM
  #24
bigtman07's Avatar
bigtman07
I used a screw driver to go inside the gromet that is there and ran my cb wire there so that I had a good seal and didn't have to drill through the firewall. Just my .02
Old Apr 30, 2010 | 11:13 AM
  #25
Laramie1997's Avatar
Laramie1997
He can't go that route if I'm thinking correctly. I want to say that the gromet that we all used isn't threre on a manual truck. Well, it is, but it has a pedal working through it.
Bub, I'll have to peer down and have a look see later today since I'm sure there are other places to use.
Old May 2, 2010 | 05:23 PM
  #26
Maxx_Magnum
I got a pic of where my wires go through the firewall, not where I previously mentioned at all.... They go through the big grommet where the big harness goes through, to the left of the brake booster...
Old May 2, 2010 | 08:07 PM
  #27
Sheriff420's Avatar
Sheriff420
it might be a good idea to wipe that down and cover it in liquid electric tape or RTV Maxx.
Old May 2, 2010 | 10:26 PM
  #28
Maxx_Magnum
ya I know sheriff... It wasn't torn that much when I first ran the wires, and I just noticed it was like that today when I took the pics... thanks for the tip!
Old May 3, 2010 | 01:50 AM
  #29
BlueBeast2's Avatar
BlueBeast2
I got so many wires shoved through that hole no more will fit LOL
