A/C vents switching?
Old Jul 31, 2009 | 02:59 PM
ram4ever's Avatar
ram4ever
Default A/C vents switching?
When I turn on the A/C vents to the dashboard they switch to the defrost vents when I accelerate and switch back when I let of the pedal,can't find what is causing this my though was a bas vacuum line but can't find which, has anyone had this problem and can help piont me in the right direction. Thanks
Old Jul 31, 2009 | 03:41 PM
Miami_Son's Avatar
Miami_Son
Do a search for 'wild vents' or 'crazy vents' to find the fix.
Old Jul 31, 2009 | 09:33 PM
dhvaughan's Avatar
dhvaughan
also see "check valves". there's 2 of them on passenger side between intake and firewall.
Old Jul 31, 2009 | 09:53 PM
eaglestorm's Avatar
eaglestorm
ck your vac line to the cruise servo under the battery
Old Aug 11, 2009 | 02:46 PM
ram4ever's Avatar
ram4ever
Thanks for all who replied, After looking over all the search threads on wild vents I came up with a plan to check on my vac lines. My 01 had a check valve already in place to the a/c vents, so I checked it with a vac gauge and it was good I then checked each line and they were good I then checked the check valve right after the manifold and found that one bad and replaced it with a new elbow to fit the new check valve and no more wild vents. Go figure repaired it all for under $6.00. Thanks again for all the help.
Old Aug 12, 2009 | 10:01 AM
Sheriff420's Avatar
Sheriff420
the one on the side of the manifold gets gummed up with oil vapors over time. mine and my dads trucks both had a bad one on the side of the manifold.
Old Aug 12, 2009 | 01:32 PM
palerider9999's Avatar
palerider9999
Was the valve purchased at the dealer? Do you have the part#?
Old Aug 12, 2009 | 02:43 PM
Laramie1997's Avatar
Laramie1997
https://dodgeforum.com/forum/2nd-gen...help-guys.html
Old Aug 12, 2009 | 03:28 PM
gobbell1's Avatar
gobbell1
Ram4ever,
What type of vac check tool did you use?
Old Aug 14, 2009 | 10:11 AM
ram4ever's Avatar
ram4ever
I used a mighty vac hand held vacuum pump or better know as a brake bleeder. I bought the check valve at pep boys and it was on the shelf with all the other vac line parts, that;s why I had to buy the one other fitting to adapt to the size for the outlet off the mainfold, it was a elbow.And also I had the vac from when I changed my brake lines.
