The best shorties?
Old Aug 9, 2009 | 11:06 PM
Rockyhigh360's Avatar
Rockyhigh360
Default The best shorties?
I know... I know... I'm better off getting longtubes for my 3/4 ton, but I want to use my stock y-pipe and get rid of those rusted exhaust manifolds.
So my question is whats the best bang for my buck on shorties? Whats the best increase in power am I looking at? Been lookin at the Eddies to go with the Air gap.
Old Aug 10, 2009 | 02:02 AM
Sheriff420's Avatar
Sheriff420
i've heard good things about the gibson ceramic coated headers.
Old Aug 10, 2009 | 07:23 AM
lastrights's Avatar
lastrights
pacesetter longtubes
Old Aug 10, 2009 | 09:10 AM
Sheriff420's Avatar
Sheriff420
theres a lot more work involved with long tubes. shorties just bolt right on so ease of installation is a bonus. unless you get some like mine where the cylinder 7 and 8 tubes curve up and block the bolts, that got a little annoying on the install.
Old Aug 10, 2009 | 10:08 AM
BigRedRam95's Avatar
BigRedRam95
I don't want to hijack the thread but what are the differences between long and short tubes besides one is long and one is short which ones would you recommend for a truck with true duals two high flow cats that has a x-pipe into two super44 MF mufflers
Old Aug 10, 2009 | 10:25 AM
lastrights's Avatar
lastrights
well the stock y-pipe is pretty restrictive also if you go shorties either edlebroc or gibson, and pacesetter if longtubes also get cerimic on what ever
Old Aug 10, 2009 | 07:45 PM
Rockyhigh360
long tubes will give you more low end torque, while shorties are geared for more flow at higher rpm, or top end torque. Longtubes require an aftermarket y pipe or crossover, and most shorties will bolt right to your existing y-pipe. For bigred, I recomend the longtubes because you already have the stock y-pipe gone and the x pipe should be fairly simple to attach to. Hope that helped
Old Aug 10, 2009 | 09:37 PM
tiggamonsta's Avatar
tiggamonsta
I have the Edlebrock ceramic coated. They fit well. There was a couple bolts that had to be tightened with a wrench, but that was not a big deal. I am also running the magnaflow direct fit cat and flowmaster cat back. The only issue I had with the whole system was that the distance between where Magnaflow stopped and Flowmaster started was about 2 feet. I just bought a piece of pipe from Pep Boys to fill in the space. I like the sound and for a motor with 153,000 it pulls decent.
Old Aug 10, 2009 | 10:31 PM
aim4squirrels's Avatar
aim4squirrels
If you have minor mods on the truck, go shorties. If you have added a cam, done head work, and/or running boost, long tubes all the way.
Old Aug 10, 2009 | 11:30 PM
Rockyhigh360
you made up my mind aim, thanks
