clunking sound from rear end?
Old Aug 11, 2009 | 02:59 PM
98ramman's Avatar
98ramman
Default clunking sound from rear end?
so it doesnt make the sound all the time i have a 98 ram 4x4 360 and when i back up for more then maybe 10- 15 feet i hear a clunking sound. it also happens sometimes when i am coming to a stop. re did the shoes in the drum that wasnt it idk what else it might be any ideas?
Old Aug 11, 2009 | 03:23 PM
Aubrey's Avatar
Aubrey
Sure it is from the rear?
Does it have the stock posi in it?
Have you checked the shock bolts?
Old Aug 11, 2009 | 03:57 PM
crazzywolfie's Avatar
crazzywolfie
have you checked you universal. the stock ones have no grease nipples. they tend to clunk when you back up more than when you are going forward.
Old Aug 12, 2009 | 10:47 PM
BigTruckn1994's Avatar
BigTruckn1994
check to see if you have a lot of backlash in your rear gear, lift up the rear and turn tire back and forth and you can tell if there is excessive backlash by how much movement it takes to hear a clunk or move the other tire.. had a similar problem.. good luck with your issue
Old Aug 13, 2009 | 02:09 PM
98ramman's Avatar
98ramman
so i had it looked at we thought it was maybe an axel bearing but when they looked at it they found some small pieces in the rear dif. dont no what it could be
Old Aug 13, 2009 | 06:57 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
Like he said, check your u-joints. I had one that was clunking all the time and it turned out that the cap had a chunk out of it and the needle bearings washed out. That thing was flopping around free inside of the remainder.
Old Aug 13, 2009 | 07:06 PM
dhvaughan's Avatar
dhvaughan
odd. i'm typing in L I M I T E D S L I P and it thinks its a naughty word.
do you have a *****ed slip (LSD) rear diff? they're known to spit out pieces of the clutch pack retainer clip thingys. sometimes they fall to the bottom and don't do any damage, other times they go through the gears and do serious or catastrophic damage.
Old Aug 14, 2009 | 01:38 AM
98ramman's Avatar
98ramman
thats what i was thinkin it was cuz it looks kind of like a clip and if i had to describe it i would say clip thingy myself.
Old Aug 15, 2009 | 04:24 PM
98ramman's Avatar
98ramman
heres a picture of the pieces tgat were found in the rear dif.
Old Aug 16, 2009 | 12:18 PM
Gav1n8's Avatar
Gav1n8
so what do you do now since u found crap in there? im in the exact same situation... different problem with noise. same result with crap in the rear.
