Newbie here w/ some questions..
#21
If your gonna do the wheel cylinders, switch them to the raybestos part # wc37337. There cylinders for a 1 ton truck and will make your truck stop a lot quicker. do a search to find out more about it.
#22
Have you done this? I have the 1500 and read mixed reviews about it. Alot of the posts were old would like to hear from other 1500 owners that have done this and how it work out?
#24
on
are the Powerstop extreme truck and tow pads ceramic? if they are then i suggest you don't get them. ceramic pads are great in theory, no metal= less brake dust, higher heat resistance= longer lasting. but without metal in the pads you loose some of the friction needed to stop the truck efficiently. i ran a set of frictionmaster ceramic pads and they were worn down after a year then i replaced them with the same pads and after about a year they weren't stopping my truck like i thought they should even though they were still really thick. i switched to the mid range wearever pads and it stops pretty good now.
#25
Not to argue with you Jason, but even with a good plenum, shouldn't there be a little oil build up around ithe inside of the plenum? Not pooling mind you, but you can pull oil in through the PCV valve and that will create some darkening of the inside of the plenum walls and plate over years. My point is I guess it would break down to amount of oil, not just the simple presence of oil.
I guess, basically, as long as you fix it once (because it is blown if you haven't fixed it yet) with either an APS or Hughes kit and Felpro (or equivalent) gasket, you should be good forever.
For Ram 1500s:
If you have a 3.9L V6 2WD, you have a 42RE (also known as A500, automatic) or a NV3500 (manual).
If you have a 3.9L V6 4WD, you have a 46RE (A518) or NV3500.
If you have a 5.2L V8, you have a 46RE (A518) or NV3500.
If you have a 5.9L V8, you have a 46RE (A518).
For Ram 2500s:
If you have a 5.9L V8, you have a 46RE (A518) or NV4500.
If you have the 8.0L V10, you have a 47RE (A618) or NV4500HD.
If you have the Cummins, you have a 47RE (A618) or NV4500HD.
#26
Power Stop’s Z36 formula offers enormous brake output for your SUV or truck under full load. The Z36 metallic pad is designed for thermal stability to give you the confidence to stop under severe conditions and prevent rotor warping. Whether you drive in the hills, haul loads or tow trailers, brake safely with Z36. Compared to the competition, Z36 pads have the highest pad bite(coefficient of friction) through the entire pedal pressure range.
#27
Lifetime warranty brakes that you always hear advertised are metallic types, and lifetime warranty pads are bad. They don't wear at all, meaning they don't give you as good of friction, meaning they don't stop you the best.
Pads are one of those things you want to wear out eventually. Granted, not after just one year, but a few to several years, yes. It means they are doing their job.
#28
Yes, lifetime pads aren't the best thing you can get, but to a poorper like me, they are a good deal to get in on. All of these parts stores assume that you will sell the vehicle before the part actually wears out. Just about any kind of wear and tear part, I will pick up that lifetime deal. I don't mind changing out free parts more often and it's saved me some money along the way. I haven't had to pay for brake pads since I got my ram. Same goes for my alternator. Before I had it beefed up, I went through 4 of them and I only paid for the first one.
Each to their own thoughts, but I'll stick with my liftimers and live with the fact that I have to change things more often.
#29
^^ Yea, I prefer lifetime parts for the same reason. If I have to replace it at least I prefer not to have to pay for them. The other way you are out the labor and cost each time. BTW Laramie where the heck do you get lifetime anymore? I know around me Kragen, (now Oreillys) stopped honoring the lifetime warranty a few years back. They still have lifetime brakes, but it doesn't cover wear and tear, just defects. That's a BS warranty as far as I am concerned.
#30
Where I live is also the home of Oreily's. They are still booming here, and their main office is here. Even if I buy a part that doesn't have lifetime on it, I know a guy that can make it that way. I've said it before, but I don't even walk into the front door of any of the Os around here. I know everyone very well and I just walk in the back and get the parts that I need.
