Quick seat fix maybe
Old Aug 18, 2009 | 04:33 PM
Eddielx's Avatar
Eddielx
Default Quick seat fix maybe
I moved my driver seat bottom to the pass side.You can't see the rip on the other..All you need is a 10mm wrench
Looks bad!
10mm bolt
Seat off Good time to clean carpet.
Looks good for 10min of work.
Old Aug 18, 2009 | 04:54 PM
torp74's Avatar
torp74
Good job. I pulled the seat cover off, turned it inside out, and sewed it up with 15lb test fishing line. I also reinforced the side where my fat *** slides across it, using some new stiff foam my wife got at hobby lobby. 22 Years in the Navy came in handy once again!
Old Aug 18, 2009 | 06:26 PM
Aubrey's Avatar
Aubrey
I have a 95 and I don't think the cushions can be swapped like that since the levers stick through the side of the seat. That was a good temp fix.
Old Aug 18, 2009 | 08:37 PM
2damnyankee's Avatar
2damnyankee
+1 your rite we 95 models cant switch out but we can take off the cover and for 35 bucks (well thats what i paid) get the whole side of the seat fixed and i looks brand new once put back on
Old Aug 18, 2009 | 09:38 PM
Ram15002ndGen's Avatar
Ram15002ndGen
Actually that lever has to come off somehow. Either it has a cap that shows a screw underneath or it needs a tool to release it. The way I look at things is, if that part wasn't born on there, there's gotta be a way to get it off. My 97 has the same design as your's and I'm sure that lever comes off.
Old Aug 18, 2009 | 09:47 PM
Laramie1997's Avatar
Laramie1997
Or, you can follow along the same lines, and just switch the foam across. It was covered on here not too long ago. Just switch the foam around, and you'll be happy.
Old Jan 22, 2010 | 12:05 AM
intense00's Avatar
intense00
Does anyone know if this will work with power heated leather seats?
My drivers seat bottom feels like im leaning to the left, and so far is the most annoying thing about the truck for me so far (6 months)
Old Jan 22, 2010 | 02:28 AM
Trey318's Avatar
Trey318
I need to do that. My upholstery isn't ripped, but the foam sure is wimpy on that edge.
Old Jan 22, 2010 | 03:39 AM
wake's Avatar
wake
seat covers work great for me..i washed em..threw em on..and ta da..did it in 5 minutes after they dried..
looks pretty good to..and mine was so bad that you could stick your whole had in there
Old Jan 22, 2010 | 06:47 AM
95RAM360's Avatar
95RAM360
my driver seat sags on the outter edge and has a tear...but is a 95....and i have a blue interior and cant find blue seats anywhere....
ill take a look into mine today and see what it requires to do the 95 seats
