98 Ram Cruise Control Quit...
Old Aug 18, 2009 | 09:46 PM
Carguycanada's Avatar
Carguycanada
Default 98 Ram Cruise Control Quit...
I have a 1998 Dodge ram 3500 diesel 4x4. A few months ago the cruise control quit. I changed both controls on the steering wheel. The light does not come on the dash and the cruise does not engage. What should I check next?? I am putting on 1000 miles a week so it would be nice to fix Thanks!
Old Aug 18, 2009 | 10:16 PM
Oren09's Avatar
Oren09
Check all vacuum lines and check valves running from the intake to the cruise control module (usually under the driver's side battery).
Check fuses. Check wiring at the cruise module.
Old Jun 11, 2011 | 03:02 AM
mca_masonry's Avatar
mca_masonry
where is the cruise control fuse for my 97' dodge 1500 4x4 ext. cab?
Old Jul 31, 2011 | 02:12 PM
lowriderman3's Avatar
lowriderman3
^^What he said..I thought I read that there is not fuse for the cruise? My light does not even come on either. Checking hoses today as I read in other post.
Old Jul 31, 2011 | 02:36 PM
There is no fuse. (there is no spoon......)
CC switch draws power directly from the PCM. If the lite doesn't come on, check continuity of the switchs. Might be a bad clockspring.
Old Jul 31, 2011 | 02:41 PM
lowriderman3
^^Thanks! Also I just read that there is no cruise light on the 95 model. Is there a light on the 94 model? I have no light at all.
Old Jul 31, 2011 | 02:47 PM
If the 95 didn't have one, it's a pretty good bet that the 94 didn't either. My 96 does though, right on the steering wheel, on the button that isn't really a button.
The early models may have worked differently as well... Haven't looked at the older service manual though..
Old Jul 31, 2011 | 02:56 PM
For the older trucks, it is fuse 10. A 2 amp fuse in the fuse block on the side of the dash.
Old Jul 31, 2011 | 03:05 PM
lowriderman3
^^Cool...Thanks brother! Going to check it out today.
Old Nov 14, 2020 | 05:42 PM
Gregory P's Avatar
Gregory P
Default 1998 dodge ram cruise problems
went to use the cruise today and nothing i have the light on the dash light up but the cruise does not engage any ideas
