Sagging Headliner
I bought the material for my dakota ex cab at a local fabric place (Hancock Fabrics) for about $22 and the spray headliner adhesive at autozone for $11. Now the important part, it is a PAIN to get this out without breaking it and scraping off the old foam is a bear BUT I did it and it looks great. One important thing to remember if you don't want it to fall, get ALL the foam off and then cut the headliner material, dry test fit and be sure it is good, lay it on the headliner exactly where you want it glued then fold 1/2 of it back on top off the other half and spray A LOT of glue covering the back of foam and the 1/2 headliner that is exposed, let it tack up a little then spray it again and let it tack up. Lay it over and start pressing it in the center outward then do same for other half. I used 2 heavy coats and I sprayed different directions on each coat. I cut it big and folded it over about 2 or 3 inches and it looks great and is holding up so far this time. First time I did it I only sprayed it on the headliner then stuck it on, it fell in a week, it is important to spray both surfaces which is why you fold it over and spray half at a time.
rhutson in NC
rhutson in NC
EDIT: OK, I pulled the overhead and dome light and had a looksee. There are points where the inner and outer roof sheetmetal come to within an 1/8" between them. Looks like the expanded foam would have minimal effect in those areas. Guess I will go the route of dropping the headliner and using Dynamat to cover the roof area. Doesn't look like it will interfere with the headliner at all. Just a pain to undo all the crap to drop the headliner.
