318 coverted to 360?
Old Aug 24, 2009 | 01:28 PM
audiomechanic's Avatar
audiomechanic
modracer: is your truck a 5-speed or auto? If it's the 5-speed, you'll need a flywheel since the flywheels between the 318 and 360 are different.
If it's an auto, you shouldn't need anything different there, just make sure that 46RE(tarted) trans is in good shape!
Old Aug 25, 2009 | 12:23 AM
modracer's Avatar
modracer
no my truck is a 4speed with over drive auto so it shuld be allright, and the motor im getting is out of a 1995 so will that still work? shuld i look for a 360 computer out of a 1999 or a 1995?
thanks kyle.m
Old Aug 25, 2009 | 12:58 AM
jasonw's Avatar
jasonw
Site Moderator
That won't be easy at all.
The 360 from 1995 used OBD I. The 318 you had/have is OBD II. Pretty different sensor setups on the two trucks. Even if you took a 1995 computer, it won't work right with your existing wiring, OBD I computers were completely different than OBD IIs.
The transmissions were also slightly different, 46RH back in 1995 as opposed to your 46RE in 1999, although that has more to do with the computer then the engine.
It'd be a whole lot easier if you were to find a 1998+ engine.
Old Aug 25, 2009 | 01:22 AM
modracer's Avatar
modracer
well the origanal motor the 99 the heads went out of it and i put a motor out of a 1994 in there so would it be OBD1 too cause we had too mess around with some sencors to make it work so would it be the same deal with the 360?
Old Aug 25, 2009 | 08:34 AM
jasonw's Avatar
jasonw
Site Moderator
Same or similar, probably.
