Fuel gauge stuck way past Full level and not coming down
Old 08-25-2009 | 11:43 PM
sstgonzo's Avatar
sstgonzo
Default Fuel gauge stuck way past Full level and not coming down
Well on my 97 SS/T the gas gauge is reading overfull and I have driven over a 150 miles so I know its off. How can I fix this and whats going on? Thanks
Old 08-25-2009 | 11:49 PM
speeddemon31176's Avatar
speeddemon31176
New sending unit probably but you could try taking a rubber shot peen hammer and bang on the tank near the pickup assembly and see if it will come unstuck. Other than that you are looking at dropping the tank ans more invasive procedures.
Old 08-25-2009 | 11:58 PM
Oren09's Avatar
Oren09
I have the same issue. I have been told to check the sending unit ground, but the wiring harness disappears behind the tank and into a plastic tubing wrap, so I'm not sure if it grounds on the frame somewhere or all the way back to the PCM..
Old 08-26-2009 | 12:19 AM
speeddemon31176
I believe it grounds back at the ecm but I am not sure. They changed so much on theses trucks over the years it is hard to tell from one truck to another.
Old 08-26-2009 | 12:30 AM
Ram15002ndGen's Avatar
Ram15002ndGen
Try filling up the tank half way and then do a few quick stops. Slosh that gas around back there really hard I see if that helps.
Old 08-26-2009 | 12:32 AM
sstgonzo's Avatar
sstgonzo
Yea I was pricing them at auto zone with a the whole assembly its 219.99...anyone have any suggestions who to buy from?
Old 08-26-2009 | 12:34 AM
sstgonzo's Avatar
sstgonzo
Haha I have no idea with halk is on it. The tank I have is a 26 gallon I think...may be wrong.
Old 08-26-2009 | 12:37 AM
speeddemon31176
Probably going to be more expensive but I would recommend going to Napa or another high quality parts store as I am sure you don't want to be dropping the tank again any time soon.
Old 08-26-2009 | 12:40 AM
sstgonzo's Avatar
sstgonzo
This is true..anyone replaced there fuel pumps? Any tricks or advise?
dakotas ram's Avatar
dakotas ram
when did it start this? did you fill it up all the way and then it did it?....if so, you might take the front of your gages off and move it back with your finger in case it just got stuck......heres a cheaper one
http://www.rockauto.com/catalog/x,ca...,parttype,6256
Quick Reply: Fuel gauge stuck way past Full level and not coming down
