No X4
Old 08-28-2009, 06:55 PM
Miami_Son's Avatar
Miami_Son
Miami_Son is offline
Well, I replaced the switch, but still have issues. It will go into 4X4, but will not hold it. Sometimes the axle disconnects after a few feet, sometimes it holds a little longer. Also found that the indicator light switch is bad, too. Looks like I will probably break down and go with a Posi-Lock kit. This vacuum system is just too unreliable. Not that I use 4X4 much, but when I do I want to know it is engaged and not be wondering about it. Anybody know where the vacuum source is on the engine for the transfer case switch?
  #22
Old 08-28-2009, 09:48 PM
Miami_Son's Avatar
Miami_Son
Originally Posted by speeddemon31176
You are referring to Posi-Lok brand cable actuators. You can get them from many places including Jeg's and Summit.
I searched both sites and no results.
  #23
Old 08-28-2009, 09:53 PM
speeddemon31176's Avatar
speeddemon31176
speeddemon31176 is offline
OK. Give me a minute and I will find it for you. http://www.summitracing.com/search/brand/4x4-Posi-Lok/
the very first one is for our trucks.
  #24
Old 08-28-2009, 10:02 PM
Miami_Son's Avatar
Miami_Son
Originally Posted by dhvaughan
after working on my vacuum system for awhile (and getting it working) and learning how fragile and mysterious it was, it put in a posilok.
How do you like it? Does it engage without having to do any acrobatics like rolling backwards? I think I'm going to go to the cable. This vacuum system is just too iffy. I'm surprised I don't see more bitching in here about it.
  #25
Old 08-28-2009, 10:08 PM
speeddemon31176
You pull the handle and it engages. No if ands or buts about it. You also get the option of two wheel low as well with that setup. Your 4wd light will still work too. the only thing is that you will have to drill a hole through the firewall unless they have a specific location like other applications and you will have to put holes under your dash to mount the handle bracket. I just checked and you have to drill an 11/16" hole in the firewall but hte kit comes with a gromett to fill the hole in. Here is the installation instructions. http://static.summitracing.com/globa...ns/pos-400.pdf
  #26
Old 08-28-2009, 10:09 PM
Miami_Son's Avatar
Miami_Son
Got it. $215 shipping on Monday. Should be here by next weekend. No wheeling for me over the holiday.
  #27
Old 08-29-2009, 10:50 AM
Sheriff420's Avatar
Sheriff420
Sheriff420 is offline
Originally Posted by Ram15002ndGen
Dude, most vehicles are made for city slickers. The most they use the 4X4 setting is to deal with a little snow, or maybe get across a flooded street. Most folks out there want convenience, and that's what car makers give them. For heavy duty stuff, you go Power Wagon.
fixed it for ya. i remember drooling over the power wagon back in 04 when i got my truck.
  #28
Old 08-29-2009, 11:23 AM
dhvaughan's Avatar
dhvaughan
dhvaughan is offline
read this before you start and drill a small pilot hole through the firewall before you drill the big one. my pilot came out in the damn steering plate.
https://dodgeforum.com/forum/2nd-gen...installed.html
oh yeah, if you let the cable get over on the exhaust manifold you'll get to do this.
https://dodgeforum.com/forum/2nd-gen...ble-stuck.html
  #29
Old 10-22-2009, 02:23 PM
projectdakota22's Avatar
projectdakota22
projectdakota22 is offline
Default Cable replacement for vacuum lines, 4 by 4
Hey, just seeing if anybody here has done this conversion, my vacuum lines are giving me problems for the 4 by 4 to the front diff diaphragm thing. I heard you can just buy a cable conversion to bypass all the problems associated with the vacuum lines, has anybody done this, will I still get the 4by4 engaged light in the dash?
Thanks
  #30
Old 10-22-2009, 03:12 PM
Aubrey's Avatar
Aubrey
Aubrey is offline
Yes, several people here have. Some like it, some don't, some have made their own.
