PLEASE Where is the crankshaft position sensor
Old 09-03-2009, 08:28 PM
RedRam01's Avatar
RedRam01
RedRam01 is offline
Angry PLEASE Where is the crankshaft position sensor
01 Ram 2500 4x4 5.9l. I can't seem to locate the CPS which is somewhere apparently on the engine block flange. somebody please help.
Old 09-03-2009, 08:48 PM
DODGEPWR's Avatar
DODGEPWR
DODGEPWR is offline
Plenty of threads posted on this subject man. If you search for crank position sensor you should find what your looking for.
Its hard to get to they say...Its on the passenger side of the truck behind the engine on top of the bellhousing.
Old 09-03-2009, 09:14 PM
RedRam01's Avatar
RedRam01
RedRam01 is offline
Talking I found it
Thanks for the feedback. Now to search for how the heck one is supposed to get to it...What a pain.
Old 09-03-2009, 09:20 PM
2damnyankee's Avatar
2damnyankee
2damnyankee is offline
YOU MUST USE THE FORCE REDRAM USE THE FORCE!!!!!!!!!!!!!!!!!!!!!!!
no seriously you just need a 10 mm or a 12mm (cant remember) and a exstention and just feel for it behind the pass side of the intake and valve cover
Old 09-04-2009, 12:19 PM
Sheriff420's Avatar
Sheriff420
Sheriff420 is offline
yep, you pretty much have to do it blind.
Old 09-04-2009, 08:58 PM
RedRam01's Avatar
RedRam01
RedRam01 is offline
I think I found it and after removing the distributor wires out of the way I was able to pull the plug only to realized that the connector Is male and the connector supplied with the new sensor is male...What the heck! Same thing happened when I purchased an O2 sensor...wrong fittings. am I missing soemething here..BTW, all parts purchased from Autozone.
Old 09-04-2009, 09:26 PM
Ram15002ndGen's Avatar
Ram15002ndGen
Ram15002ndGen is offline
Doesn't that tell you something?
Old 09-04-2009, 11:02 PM
dhvaughan's Avatar
dhvaughan
dhvaughan is offline
careful, you may have removed the wire from the oil pressure sending unit. its a black vertical tube about 3 or 4 inches tall, just to the left of the distributor.
you're close, but dig deeper.
Old 09-05-2009, 01:10 AM
RedRam01's Avatar
RedRam01
RedRam01 is offline
you're right Dhvaughn. I pulled the wrong wire. I finally got to it and replaced the unit. What a freaking pain in the ****...now I know why my mechanic said it ain't no fun since they put the computer's in cars. Now all I have to do is fire it up and see if that solved my stalling issues. Thanks to all who provided input.
Old 09-05-2009, 02:23 AM
cmckenna's Avatar
cmckenna
cmckenna is offline
Never buy your parts at Autoclone. What they do is buy seconds. I went though- lets's see, I think it was around 3 T-stats before I got really f-ing pissed off and went back in there where I finally was told "hey, don't buy our T-stats". "They are all over the place as far as temp ratings are concerned"
Those T-stats are made in Mexico and, like most of the stuff made down there- it doesn't work for ****.
Quick Reply: PLEASE Where is the crankshaft position sensor
