lift
Old 09-12-2009, 05:11 PM
Miami_Son's Avatar
Miami_Son
Miami_Son is offline
No Worries. Figure about $1,100-1,500 per axle for a gear swap and setup.
Old 09-12-2009, 05:16 PM
wakullabronco's Avatar
wakullabronco
wakullabronco is offline
omg i wanted a price of the parts not parts and labor lol.
Old 09-12-2009, 05:23 PM
dodge15004x45.9's Avatar
dodge15004x45.9
dodge15004x45.9 is offline
Thats just some of the price you pay to run big tires.
Old 09-12-2009, 05:27 PM
wakullabronco
What do you mean i just wanted to see ifs there anyone that might know the price for the 60's not to set them or anything just parts.
Old 09-12-2009, 05:29 PM
dodge15004x45.9
I was talking about ball joint, u joint, hubs, tires, etc.
Old 09-12-2009, 05:34 PM
Miami_Son's Avatar
Miami_Son
Do you know how to setup a ring and pinion? It takes special tools and specific knowledge beyond the ability of most mechanics. It isn't the kind of thing you DIY without knowing how to do it. Just a ring and pinion set will run you $350-500 per axle, but you'll also need new bearings and seals and a shim kit, so figure about $500-600 per axle minimum.
Old 09-12-2009, 05:48 PM
wakullabronco
The d44 i had to put money in with doing 8 hub bearing on the drives side never the pass side. I had 2 of my teachers look at them which they are both ASE master tech. No one could find the problem U-joints are fine, axle shaft had no run out, axles nut torque to specs, hub bolts torque to spec. Then drive 3 miles down the road and then go bad lol. Keep in mind with 31/10.5/15 tires. The only reason i am going to 60's is because my rear end took a **** and a 9.25 rear end's are going for 600-800 with the 3.92 ratio. I was thinking that the 60's would hold to a 38 ground hawg. I was just asking if anyone has ran a 38 with a 3.54 ratio and not have problems..
If i can get a new R&P, carrier, master kit for front and rear under 800 ill change them out.
Thanks, James.
Old 09-12-2009, 05:56 PM
Miami_Son's Avatar
Miami_Son
You mean other than the truck being a slug and having no power on takeoff?
Wake up, you're dreaming.
Old 09-12-2009, 06:10 PM
wakullabronco
lol i didnt want a race truck but it would be nice.
OK i just got off the phone with 4 wheel parts and they said for new R&P(5.13), carrier to fit over a 4.56 and 2 master kits he said he could do $875 not shipped though. I hope he got everthing i told him over phone or im going on a killing madnes.
Old 09-12-2009, 06:15 PM
dodge15004x45.9
Lol I can get 4.56's for under 600 w shim kits front and rear.
Quick Reply: lift
