5.9L starving, dies intermittently
Old 09-14-2009 | 10:30 PM
Miami_Son's Avatar
Miami_Son
MAF sensors are used primarily on vehicles that run in closed loop most of the time. The Dodge only runs in closed loop when idling and when cruising, otherwise it is in open loop mode.
Old 09-14-2009 | 10:39 PM
97ram5.9's Avatar
97ram5.9
it was the fuel pump! thanks
Old 09-14-2009 | 11:07 PM
al hass's Avatar
al hass
souns like exact same problem i had, they checked every sensor and fuel pressure. not the problem. think it was plenum or intake gaskets, took it for a drive didn't do it again. led to other problems as they may have screwed up the installation led to other problems
Old 09-14-2009 | 11:23 PM
1fast2liter's Avatar
1fast2liter
not true.... the eclipse uses a maf and they dont always run in closed loop.... they cant not running turbo...
Old 09-14-2009 | 11:39 PM
Miami_Son's Avatar
Miami_Son
This is the Dodge RAM truck forum. Comments above are related to that fact. The Eclipse and vehicles like it use the MAF sensor and closed loop operation far more than these trucks do.
Old 09-15-2009 | 01:05 AM
rafter40's Avatar
rafter40
zman... why did you say to unscrew the front 02 sensor and see what it does? the reason i ask is my truck does a similar thing where i will just be driving along and then i lose power and just watch my rpm drop even if i stomp on the gas. I checked the codes and it said i need a new 02 sensor, would this (most likely) fix the problem? when i checked it, it was sending out eratic voltages.
Old 09-15-2009 | 01:33 AM
Sheriff420's Avatar
Sheriff420
that should tell you to change it right there.
zman said to unscrew it because when the catalytic converter gets plugged up the truck will loose rpms and feel like its stalling along with random cylinder misfires. unplugging the sensor acts as a temporary pressure relief to let you know if it is the cat that is causing your symptoms.
Old 09-15-2009 | 06:23 AM
zman17's Avatar
zman17
Retired Moderator - RIP
Sherriff is right, that is the reason I said to unscrew it.
Old 09-15-2009 | 11:07 AM
bigtman07's Avatar
bigtman07
Sorry guys I was thinking of my last truck. It was a gm and they used that I forgot about dodge not using one. DOH!
Quick Reply: 5.9L starving, dies intermittently
