Holley throttle body?
Old Sep 15, 2009 | 08:06 PM
  #31
crazzywolfie's Avatar
crazzywolfie
Originally Posted by zman17
You are not going to put an obd1 pcm in a obd2 truck, you might get the motor to run, but nothing else on the truck will work.
you would be surprized what else might work. i'm not disagreeing with you but i'm just saying that it might acually work like that. i put a 87 318 in a 91 that had a 239 and all i did was hook everything up and it worked. throtlebody to carburator without changing the wires in the cab.
Old Sep 15, 2009 | 08:07 PM
  #32
Hahns5.2's Avatar
Hahns5.2
zman is right. As long as you're just swapping the engine and keep using the 98 manifold and sensors it will run just fine! It's the same damn engine!
Old Sep 15, 2009 | 08:10 PM
  #33
zman17's Avatar
zman17
Retired Moderator - RIP
If the manifold is swapped then whats the prob? The only other sensors are the crank and the ect and maybe a seperate temp gauge sensor on the 95 block that can be just plugged. You can't just stick the 95 motor in the 98 without doing what Miami said plus a whole lot more to get it to work. Not worth it, that's why swapping the intake and a couple other things is what is normally done.
Old Sep 15, 2009 | 08:12 PM
  #34
crazzywolfie
Originally Posted by wjxavier
i just have a feeling that it wont work like it should. i guess we'll see won't we. lol
oh btw...i'm about 99.99% positive that you CAN'T swap a single core processor for a dual core processor and keep the same motherboard. the pins wouldn't even line up. not even close.
a socket 939 will run a singe or dual core processor. this engine swap should work.
Old Sep 15, 2009 | 08:13 PM
  #35
BlueBeast2's Avatar
BlueBeast2
I need laid
Old Sep 15, 2009 | 08:18 PM
  #36
zman17's Avatar
zman17
Some things in the cab might work,but
The rest of the drivetrain sensors are different from 95 to 98. The tranny operates differently also , RH opposed to RE tranny.
Old Sep 15, 2009 | 08:24 PM
  #37
wjxavier's Avatar
wjxavier
i stand corrected...i think i was thinking more along the lines of a 64-bit system vs. a 32-bit...
Old Sep 15, 2009 | 09:42 PM
  #38
Gav1n8's Avatar
Gav1n8
this thread is pointless... You all should look up Instant messenger haha. Its like i'm taking a computer class. Good thing i'm not a mod or this would be deleted
Old Sep 15, 2009 | 10:04 PM
  #39
BlueBeast2's Avatar
BlueBeast2
lol I'm dissapointed in these guys as well
Old Sep 15, 2009 | 10:47 PM
  #40
wjxavier's Avatar
wjxavier
we were discussing the swap of a obd1 engine to a obdII system...the whole computer thing was a reference that was made earlier.
