Horrible RIDE NEED HELP!
Old Sep 23, 2009 | 02:11 PM
tankht56's Avatar
tankht56
Default Horrible RIDE NEED HELP!
How's it going guys i need some opinions from you guys that have changed out the front and rear shocks or anything to help the ride of your ram
i know it's a truck but i shouldnt be able to feel every single bump or rut in the road.. it seems if i roll over a dime ill feel it lol. any help will be appreciated.
Old Sep 23, 2009 | 02:35 PM
Aubrey's Avatar
Aubrey
You didn't mention anything about your tires.
Old Sep 23, 2009 | 02:45 PM
tankht56's Avatar
tankht56
tires are fairly new 20" goodyear eagle gt with about 10,000 miles on em
Old Sep 23, 2009 | 03:21 PM
Miami_Son's Avatar
Miami_Son
20" wheels=low profile tires. That means very little tire sidewall flex, reduced bump absorption and more road feel transmitted to the wheels and eventually the suspension and occupants. That's the price you pay for running oversize wheels.
Old Sep 23, 2009 | 03:35 PM
tankht56's Avatar
tankht56
yeah i understand that. what would you recommend if i just wanted to get new shocks front and back?
Old Sep 23, 2009 | 08:41 PM
Trey318's Avatar
Trey318
Is it lowered or lifted?
Old Sep 23, 2009 | 08:47 PM
Twisted Metal's Avatar
Twisted Metal
Shocks are not gonna solve the problem. I run 20's myself. Mind you 20's didn't become standard till 2002. Our Rams were designed and spec'd with either 16" or 17" rims. So, bigger wheel more unsprung weight, lower profile tire (for clearance) and taxing the suspension more so than stock wheels. Yes my ride is harsh as compared to other Rams I had. But I expected and accepted it. Shocks will not magically make the ride better. Now that I probably wasted my breath and time saying this, to your original question.
Bilsteins, the offer shocks for both 2 and 4wd. Run you anywhere from 200-250 depending on where you shop.
Old Sep 25, 2009 | 01:49 AM
tankht56's Avatar
tankht56
no you didnt waste your breathe bro thanks for the info i thought my suspension needed work but if you have the same systems guess i gotta live with it. but at what point does the original suspension parts need to be changed out?
Old Sep 25, 2009 | 06:56 AM
Twisted Metal
You will need to jack the front end up, take the wheels off and look. Inspect the pitman and drag link arm. Grease if needed. You should be greasing the front end at every oil change for proper maintenance. Just give everything a good once over, wiggle the rotors side to side and up and down for tie rod/ball joint looseness. On my truck, it still has the factory "greased for life" steering parts. Yes those will changed soon, there is nothing wrong with them and my front end is tight as a drum. I just don't like not having a grease fitting in a wear/movement area.
Old Sep 25, 2009 | 08:33 AM
halfamil's Avatar
halfamil
Shocks didn't change anything on my truck.I've changed them 3 times.Running the high end Bilstiens now and can't tell any difference between in them and the worn out stock shocks that were on it years ago.Mine is a 4x4 though I didn't see if you had a 2W or a 4WD
