so is this really the steering box?..
Old Oct 4, 2009 | 06:36 PM
  #51
zman17's Avatar
zman17
Retired Moderator - RIP
It needs to be done with the truck running and the front wheels raised, as mentioned above. It does nothing if the truck is not running. And you don't do it all at once, you should do a little at a time and wait for the air bubbles to disappear.
Old Oct 4, 2009 | 07:36 PM
  #52
townsley4's Avatar
townsley4
yea the instructions said raise front of vehicle off the ground. i did that, then it said make sure you keep the fluid level where it is supposed to be, and turn the steering wheel all the way left and all the way right with the engine OFF 20x. so i did that. then it said START the engine and turn it from left to right with the engine on...i did that about 20x. the steering is nice, but the pump is noisy...maybe i didnt do it enough, but i did it to the point where i couldnt see anymore bubbles coming up in the pump.
Old Oct 4, 2009 | 08:33 PM
  #53
zman17's Avatar
zman17
What brand gear box did you buy? I dont want to go back and look if you already said, LOL. sorry and you are using the same PS pump, not a new one right?
Old Oct 4, 2009 | 08:50 PM
  #54
townsley4's Avatar
townsley4
bought a 300$ one from autozone since you guys said not to get cardone parts. the one i have is by atsco. and yea im usign the same ps pump as always, just new fluid and hoses. no leaks yet..
Old Oct 4, 2009 | 09:25 PM
  #55
zman17's Avatar
zman17
As far as I'm concerned, anything is better than a Cardone, but who know's. I hope you just have some air bubble issues that will work them selves out.
Old Oct 5, 2009 | 12:08 AM
  #56
townsley4's Avatar
townsley4
yea me 2. i mean..it turns really easy and fine, but it just makes some noise when turning...also at full lock...the high pressure hose jerks right when the steering wheel hits full lock, and the hp hose jumps a little from the pressure. is it supposed to do that?
Old Oct 5, 2009 | 01:01 AM
  #57
004x41500's Avatar
004x41500
i think so, i mean commmon sense tells me that when youre pushin hp fluid through a hose, and the output end srops it seems to me that the hose would jump a bit. similar to a hydraulic system on a loader or anything else.
Old Oct 5, 2009 | 07:45 AM
  #58
zman17's Avatar
zman17
Just make sure it not rubbing on anything.
Old Oct 5, 2009 | 09:03 AM
  #59
townsley4's Avatar
townsley4
yea im made sure its not rubbing on anything, i ziptied it. anyway....its still loud this morning, and there seems to be this sucking sound coming out of the right side(drivers side). sounds to me like around the valve covers....its a weird sound, like sucking through a straw drinkin a empty milkshake. lol thats what it sounds like. anyone familar with this?
