Help!! What is this i found in my transfer case? (pics)
P.S I couldn't take my front drive shaft off when removing the trans, I would have the shifter on 4x4 but when trying to get the bolts off, after some resistance the drive shaft would spin.
to take the front shaft off you need to put a pry bar in the yoke where it connects to the front differential and have it resting on the control arm. that will keep it still so you can take the bolts out.
since you have it off the truck you can put a pry bar in the yoke where it attaches to the transfer case and have the other end of the bar on the ground to keep it still while you remove the bolts. you might have to sit on the transfer case to keep it still while you crack the bolts loose.
or you might be able to rest the pry bar against the transfer case.
Cool, i will be installing the tranny tonight, my biggest concern is remembering where all electrical and vacuum components go!!!!! Anny suggestions? I really hope I don't screw this one up. Ill keep you guys updated
