Overhead console upgrade
Old Sep 4, 2019 | 10:59 PM
  #71
phathaithaihaorg's Avatar
phathaithaihaorg
Then all you need is the sensor and the wiring from that connector to the sensor
Old Sep 5, 2019 | 01:47 PM
  #72
NitrousNic's Avatar
NitrousNic
Originally Posted by Cholmes
I did this with mine except I run two wires to the ODB II plug. Worked fine. That was a few years ago but the wires got disconnected and I can’t remember what two holes they went to in the ODBII plug. Does anyone know? I would appreciate if someone could let me know.
Do you think you could elaborate on your situation? I recently did the swap and the overhead console is only reading ccd. I know it's because of the CTM but if I don't have to swap it out that'd be great.
Old Sep 6, 2019 | 08:19 AM
  #73
Chris Holmes's Avatar
Chris Holmes
Well there are two wires that come from the console that are for data for the ECU. Instead of trying to find the correct ones and cutting in to them I just shoved them in the front of the ODBII port, same thing. The other wires in the console are for temp, and a couple other things. If you use the ODBII like I did the compass, and fuel economy, miles to empty will all work as it pulls from the ECU. I have to find a wire diagram of the ODBII port to figure it out again. I think it is the two top right or bottom right or something like that. As I said I can't remember.
Old Sep 6, 2019 | 08:24 AM
  #74
NitrousNic's Avatar
NitrousNic
What's year is your truck?
Old Sep 6, 2019 | 09:44 AM
  #75
Cholmes's Avatar
Cholmes
2002 2500. 2nd gen
