First truck, 96 dodge 1500 5.9 (auto) questions and concerns
Old Oct 14, 2009 | 10:42 AM
GsxR1000Ryda's Avatar
GsxR1000Ryda
Default First truck, 96 dodge 1500 5.9 (auto) questions and concerns
I just recently picked up my first ever truck (after only riding motorcycles for the last 5 years). It's a 96 Dodge Ram 1500 5.9 ltr automatic. I havnt really had to many issues with my truck but in the last couple of weeks Ive noticed some weird characteristics.
first, I just picked up some new tires for my truck and I notice when I'm parked and shift it in drive, every now and then when i first start rolling I sometimes feel a jolt. It feels like something may be working harder to move the new tires (drive train possible, i dont know). This only started happening once I got new tires on and does not happen everytime.
Also, It's just now starting to get cold in California and I noticed when I was driving to work in the morning, It appeared my truck wasn't kicking in to over drive. Later in the day, when I was driving home, over drive seem to be working just fine. Does the transmission need to warm up to a certain temp before over drive gets enabled?
Like I mentioned, This is my first truck and I'm pretty much mechanically declined. I appreciate any suggestions.
Old Oct 14, 2009 | 10:51 AM
Aubrey's Avatar
Aubrey
The jolt sounds like a possible tranny problem. It could be other things but, I would lean towards having a full tranny service done on it so you know it has good fluid, a new filter, and bands adjusted.
The lack of OD in cold could be your switch. I believe the OD switch is a vacuum switch and you could have some shrinkage in the cold letting the vacuum drop off.
Old Oct 14, 2009 | 10:55 AM
GsxR1000Ryda
Makes sense, so if I get a full tranny service would they be able to indicate if it needs a rebuilt or how much longer it'll last.
Also on the OD/Vacuum switch, Would that be a matter of buying a switch?
Old Oct 14, 2009 | 11:58 AM
95RAM360's Avatar
95RAM360
how many miles does it have and is it the original tranny?
Old Oct 14, 2009 | 12:16 PM
GsxR1000Ryda
118,000 and that I dont know. The guy i bought it off picked it up at a auction and only owned in for 2 month.
Old Oct 14, 2009 | 02:05 PM
Aubrey's Avatar
Aubrey
Don't tell the tranny service shop that or that it is doing anything funny. Just tell them you need a fluid and filter change and band adjustment. Then let them tell you if something looks funny.
Probably not. Probably just a dried out hose at a connector leaking.
Old Oct 14, 2009 | 03:13 PM
95RAM360's Avatar
95RAM360
118 is to early for them to blow, on the other hand it was from an auction so the previous owner could have towed alot with it, been hard on it, you just dont know, but yea do the service and let us know whats up
Old Oct 14, 2009 | 03:19 PM
charlie1935's Avatar
charlie1935
Transmission does have to warm up before O/D will work if the ambient temperature is low enough.
I don't know the exact temp, but it is normal.
Old Oct 14, 2009 | 03:20 PM
97black_ram's Avatar
97black_ram
Not sure about the jolt your getting but for when it gets cold, the PCM won't allow the transmission to shift into O/D until the fluid reaches about 100 degrees.
Old Oct 14, 2009 | 03:23 PM
GsxR1000Ryda
thanks guy for all the input. Truck is going into the shop right after work
