single plane intake manifold
Old Oct 16, 2009 | 02:58 AM
helms's Avatar
helms
a single plane intake will have an increased top end power while sacrificing throttle response and low end torque.
If this engine is going to be in a daily driven 4x4, a single plane will cause more headaches than the keg you have on there now.
Old Oct 16, 2009 | 12:31 PM
Hahns5.2's Avatar
Hahns5.2
Originally Posted by dodgeram07
but Hahns5.2 is right on the m1 and a little bottom end lose,,,, and air gap is good all the way around
just wanted to put that out there
Someone did dyno's between the two on another forum and claimed they both made the same power/torque with the same curves. IMO the AirGap is way overpriced with no advantage over the M1.
Old Oct 16, 2009 | 01:01 PM
Mike Roma's Avatar
Mike Roma
Timidone, make SURE you know exactly what you're getting if you order one.
The STOCK "kegger" is a single plane. There is more than one "M1", not all will work for you.
Old Oct 16, 2009 | 01:33 PM
dodgeram07's Avatar
dodgeram07
and that is your IMO no bigger,,, back be i desided to go with just the hughes new 1/4 belly pan i was thinin of getting a new intake,, so i reseched m1 and then at the same time the air gap come out
all of people(you too) that put the M1 of Dakota's with very very little to none of the bottom end lost,, as far as i know people said that the m1 push the power range up to higher rpms for racing.
the people i found with rams (weight more) loss bottom end
so far all report said the the air gap has no bottm end loss
my reseach was on stock and close to stock rams and dakotas
its kinda like the kegget mod cut the runners and give of sum QT but then regain HP gains,,, like a tade off
IMO they both are overpriced but may that the chevy guy in me saying that( because if i was buyin a intake for 600 dollars the carb would come with it,,but thats no apple to apples)
but still as i know the m1 push to power band up to a higher rpm
just putting that out there and not trying to make anyone mad(hope we are on the same page,, we all are still learning every day)
Old Oct 16, 2009 | 05:08 PM
Hahns5.2's Avatar
Hahns5.2
I'm just saying evreyone claims there's no low end loss with the air gap, so far only one person has done a comparison and claims they're the same. Like I said, a few mods will more than bring back the low end loss, I can break em loose in the rain in 3rd at only around 2K rpms with no clutch help, couldn't do that stock.
