Serpentine belt squeal
Old Oct 16, 2009 | 04:51 PM
texaschick's Avatar
texaschick
Default Serpentine belt squeal
Ok so my water pump went out and i replaces it which sloved everything but one thing I am getting a bad squelling from the belt area cant figure it out I have changed the whole tensior puller assy, changed belt because i put a small amount of belt grease on the outside of the belt and it stoped so i figured with all the coolent leak that the coolent made the belt strtech so i changed the belt but still VERY VERY LOUD
Old Oct 16, 2009 | 05:16 PM
95RAM360's Avatar
95RAM360
may be the fan clutch
Old Oct 16, 2009 | 05:40 PM
texaschick's Avatar
texaschick
How would you check the fan clutch
Old Oct 16, 2009 | 06:19 PM
zman17's Avatar
zman17
Retired Moderator - RIP
What brand belt did you buy? Make sure it has the same amount of ribs as the pulleys. (or the old belt if you still have it. Don't use belt dressing either.
Old Oct 16, 2009 | 06:24 PM
charlie1935's Avatar
charlie1935
Take the belt off and turn each pulley by hand and see if one of them feels rough or has any play in and out and also side to side.
Old Oct 16, 2009 | 06:42 PM
zman17's Avatar
zman17
And while you have the belt off, use a wire brush and some brake cleaner to clean the grooves of the pulleys.
Old Oct 16, 2009 | 07:28 PM
texaschick's Avatar
texaschick
So should all the pullies have no play in them what so ever?
Old Oct 16, 2009 | 07:44 PM
dhvaughan's Avatar
dhvaughan
i'd say they should have no play, no wobble. rotation should be easy and smooth, no roughness, no binding. if you spin the pulley as hard as you can, it should not roar, or sound dry.
you've got several possibilities. tensioner pulley, idler pulley, alternator, water pump, AC compressor, and PS pump.
Old Oct 16, 2009 | 09:45 PM
Miami_Son's Avatar
Miami_Son
In the future, please use more descriptive thread titles to make it easier for someone with the same problem to find this thread in a search. Thanks.
Old Oct 17, 2009 | 01:52 PM
charlie1935
How else would you describe a squealing belt?
