lifting the rear
Old Oct 18, 2009 | 10:18 AM
Sheriff420's Avatar
Sheriff420
Default lifting the rear
now i know everyone says you can go 3" on stock shocks but my question is does that apply to only the front end or does it also cover the rear? i'm thinking about getting some 2" add a leafs just for a little more height.
i just leveled the truck yesterday and now i'm wanting to raise the rear and put the rake back in it because that will mean more height. the main reason i leveled it was to get some more height to keep the tires from rubbing the fenders, i wasn't concerned about getting it level.
this is what i'm thinking about getting- http://cgi.ebay.com/ebaymotors/2-94-...Q5fAccessories
am i going to need new u bolts for that?
this is the other one i was looking at but i'm leaning toward the skyjacker because i figure they would take longer to flatten out. correct me if i'm wrong because thats 22$ cheaper.
Old Oct 18, 2009 | 04:21 PM
dodge15004x45.9's Avatar
dodge15004x45.9
There both leafs In due time they will both sag. You are mostly paying for them "name". I would just put new shocks on it anyway. (better ride.)
Yes you will need new u bolts and nuts.
And call them and work them on the price
Old Oct 18, 2009 | 04:30 PM
Sheriff420's Avatar
Sheriff420
my shocks are brand new, that's why i was asking. i also figured that skyjacker would use a stronger steel since they have that name to protect, but if the tuff country leafs are just as good i will go with them.
Old Oct 18, 2009 | 04:31 PM
zje400ex's Avatar
zje400ex
You can add 1" in the rear before you need new shocks. Anything over that i would recommend buying the 2-3" lift shocks for those aal. That is info i got from topguncustomz. You can lift the front up 2" and still use stock shocks. I think it cost me around $130 for rough country shocks and four black shock boots when i lifted mine
Old Oct 18, 2009 | 04:36 PM
95RAM360's Avatar
95RAM360
you say you can only go 2 in. in the front. Sheriff just did a 2 1/2 in leveling, and those are stock shocks right?
Old Oct 18, 2009 | 04:42 PM
zje400ex's Avatar
zje400ex
Sorry, i just looked up on roughcountry.com and they say you can use stock for the 2.5" level. Sorry about that.
Old Oct 18, 2009 | 04:43 PM
dodge15004x45.9
130 bucks!!! Holy cow! I paid the extra 20 for gassers. How much did that lift cost you?
zje400ex's Avatar
zje400ex
Here is what roughcountry says from there install write up...
Rough Country highly recommends new application valved shocks made for 2.5” of lifted height and additional travel
be purchased for this application. If new shock absorbers were purchased, install with supplied hardware. If stock
shocks are being used, install using factory hardware/bushings.
Old Oct 18, 2009 | 04:47 PM
95RAM360's Avatar
95RAM360
and my rear can only go up 1 in???????? i just bought suspension all around (stock size) and i want to put 3in. blocks for the rear. now you're telling me i gotta get new shocks for that?? damn...
Old Oct 18, 2009 | 04:51 PM
dodge15004x45.9
Sometimes it pays to do your home work for future plans/mods.
