Dropping valve body
Old Nov 8, 2009 | 08:40 PM
  #41
aim4squirrels's Avatar
aim4squirrels
that would have sucked.
Old Nov 8, 2009 | 08:43 PM
  #42
xray99's Avatar
xray99
You can say that again !
Old Nov 8, 2009 | 08:46 PM
  #43
aim4squirrels
Old Nov 8, 2009 | 08:50 PM
  #44
xray99's Avatar
xray99
Ok Champ, that'll do !
Old Nov 11, 2009 | 04:30 PM
  #45
xray99's Avatar
xray99
Made some progress today.
Valve body is on finger tight, made it pretty easy with the hillbilly hoist. Kept it right in position while I got the snap ring on, then jacked it all the way up, got a couple bolts in and removed the jack
Was a bit worried cause I didn't track where the bolts go as good as I could have, I did organize them by front, rear and side though.
Appears I lucked out, all threaded up to tightness, I'm guessing if I had a long bolt in a hole meant for a short bolt, it wouldn't go all the way in.
Still finger tight though, gotta get a decent torque wrench tonight, the ones I have are all bent up.
So looks like I'll know within a couple days if my truck will drive.
Old Nov 11, 2009 | 09:37 PM
  #46
aim4squirrels
100 in/lbs. Only 100 in/lbs.!!!!
Old Nov 11, 2009 | 10:49 PM
  #47
Trey318's Avatar
Trey318
Good luck bro. I dropped my valve body tonight. Decided to throw a shift kit in and clean things up. The pan was horrible, and the vb wasn't that good either. I think starting off in second gear all last week while my governor solenoid was out burnt up a bit of clutch material.
Old Nov 15, 2009 | 05:25 PM
  #48
xray99's Avatar
xray99
Well, I got everything together rather nicely, unfortunately for me the truck still has the same symptoms that I was told the harness replacement would fix.
When in drive, it lurches, shudders and shuts right off.
I guess my next stop will either be a repair shop or junkyard, haven't decided which yet.
Old Nov 15, 2009 | 05:29 PM
  #49
zman17's Avatar
zman17
Retired Moderator - RIP
That sucks, go to the JY and get a used PCM.
Old Nov 15, 2009 | 05:35 PM
  #50
xray99's Avatar
xray99
What makes you think a used PCM would help ?
