Dana Super 60 Installed!
Old Oct 21, 2009 | 10:06 PM
BRRMudderTrucker's Avatar
BRRMudderTrucker
Alright, I'll try and break it down for ya:
Rear end- $500.00-craigslist (but I got lucky, saw one on ebay recently-1500.00
Parking brake cables- 55.00
Body lift- 200.00
Wheels/tires/new shocks-2500.00
Ring/pinion- 300.00
Drive shaft mod- 500.00
Tools/shop supplies/gadgets-500.00
In all with the body lift and installing the front ring and pinion (the hardest part!) It took about 3 weeks, most of which was about 4 hr/weekday due to work.
Where in washington? south?
Northwest, seattle area
Last edited by BRRMudderTrucker; Oct 21, 2009 at 10:25 PM. Reason: forgot the time
Old Feb 14, 2012 | 11:45 AM
Wh1t3NuKle's Avatar
Wh1t3NuKle
Hope you are still checking this out here. Would like to know your status on this axle?
Anything to report good/bad/other? Comparison to any other rear swap.
Thanks
Old Feb 14, 2012 | 11:54 AM
Hasn't been around for better than six months..... Don't hold your breath on an update.
Old Feb 14, 2012 | 11:55 AM
Wh1t3NuKle's Avatar
Wh1t3NuKle
Yeah, I took a gander at that. Can only try! I mean, it IS V-day.
Old Feb 14, 2012 | 12:03 PM
Offer him candy for an update?
Old Feb 14, 2012 | 12:12 PM
Wh1t3NuKle's Avatar
Wh1t3NuKle
Too much of a commitment right there. This candy is conditional.... lol
Super 60 search hasn't been that great for me, which is probably my lack of keywords expertise.
Trying to determine or compare an 05 SRT-10 rear super 60 to a 01 Dana 70.
They seem quite comparable in shaft spline (35), options, strength, etc. Curious what the "breaker" could possibly be to decide.....
Old Feb 14, 2012 | 01:05 PM
merc225hp's Avatar
merc225hp
I don't know if you have these specs.
Edit: If the pinion shaft dia is the same as the regular Dana 60, and the super 60 having the bigger ring gear I would place the weak spot at the pinion shaft. Dana 70 would be my choice out of the two.
Dana 60
Ring gear diameter: 9.75
Carrier breaks: 4.10-down or 4.56-up
Pinion shaft diameter/splines: 1.625/ 10spl (early) 29 spl (late)
Axle shaft diameter/splines: 1.31-16 (early, full float), 1.31/30 (late,full-float), 1.50/35 (semi-float)
Available ratios: 3.31, 3.54, 3.73, 4.09, 4.10, 4.30, 4.46, 4.56, 4.88, 5.13, 5.38, 5.86, 6.17, 7.17,
Dana Super 60
Unable to locate; Pinion shaft diameter
Ring Gear Diameter: 10.0
Ring Gear Bolts: 12
Cover Bolts: 12
Carrier Breaks: 4.10 / 4.56
Axle Spline Count: 35
Float:
Semi-Float Type:
Pinion Support: False
Axle Lugs: 8
Dana 70
Ring gear diameter: 10.5
Pinion shaft diameter/splines: 1.75/10 (early) or 1.75/29 (late)
Axle shaft diameter/splines: 1.50/23 (early), 1.50/32 (late Dodge) or 1.50/35 (late)
Available ratios: 3.07, 3.21, 3.42, 3.54, 3.73, 4.10, 4.56, 4.88, 5.13, 5.87, 6.17, 7.17
Dana 80
Ring gear diameter: 11
Carrier breaks: 3.73-down or 4.10-up
Pinion shaft diameter/splines: 2.0/37
Axle shaft diameter/splines: 1.50/35 or 1.58/37
Available ratios: 3.31, 3.54, 3.73, 4.10, 4.30, 4.63, 4.88, 5.13
Old Feb 14, 2012 | 06:45 PM
Wh1t3NuKle's Avatar
Wh1t3NuKle
Canned the SRT-10 option, even though it had lots of sweeteners. Biggest limitation is R&P options. That is only killer here.
Some helpful info though:
http://en.wikipedia.org/wiki/Dana_60#Dana_Super_60
The Dana Super 60 is an upgraded version of the Dana 60 front axle.
Differences in the Dana Super 60 versus the regular Dana 60:
Larger and thicker diameter steel tubes (3.75 inches diameter and 1/2 in thick)
Larger ring and pinion which increase the contact area and overall strength.
Larger Universal Joints which increase strength and steering angle.
Super 60s use 1550 Universal Joints.
Net formed spider gears for increased strength.
All made with 35 Spline axle shafts.
This axle was used only as a medium duty unit until the Third Generation F-450 Pick up began production. The Third Generation F-450 pick up is a light duty truck. This axle is still used in the medium duty F-450 and F-550 4x4 trucks as well.
