Identify rear end
Old Mar 28, 2020 | 03:14 PM
  #31
Originally Posted by Jason Lowry
I have a 2002 dodge ram 1500 4x4 4.7. What gears do I hav . ? I was told 9.25/ 3.92
Read my reply. It's right above your first post with this question. Click the link. Give it your VIN. That will tell you what your gear ratios were from the factory.
Old Feb 6, 2021 | 11:05 AM
  #32
Jeremiah Hilston's Avatar
Jeremiah Hilston
A 2015 eco boost ram that has a 3.55 gear ratio. What size is the ring gear in the rear end?
Old Feb 6, 2021 | 11:19 AM
  #33
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
You need to post on the 4th gen section. Also there is no "Eco boost" Rams that's only for Fords
Old Nov 29, 2022 | 06:34 PM
  #34
mine1411's Avatar
mine1411
Default 2000 1500 ram Laramie 5.9l 4wd
Does anyone know wish my rear end I have. Can't make out nothing. Thanks.
Old Nov 30, 2022 | 06:43 AM
  #35
Moparite's Avatar
Moparite
Old Nov 30, 2022 | 01:54 PM
  #36
mine1411's Avatar
mine1411
Originally Posted by Moparite
9 1/4
.. Im not exactly sure eon Wich ratio I have. One tag says 2749 an the other it looks like 3 5 . The tags on the bolts of the pumpkin
Old Nov 30, 2022 | 08:44 PM
  #37
AtomicDog's Avatar
AtomicDog
Lightbulb
Can you please post a photo of the tags here for folks to see?
Old Nov 30, 2022 | 08:48 PM
  #38
3.55 most likely.
Old Nov 30, 2022 | 11:24 PM
  #39
AtomicDog's Avatar
AtomicDog
That's what I suspect as well, however, it's good to see the tag to verify.
Old Dec 11, 2022 | 07:48 AM
  #40
mine1411's Avatar
mine1411
Default Pics
I tried to take a picture but none of them came out good enough to read.. what I said in a previous comment. Is the numbers on each tag
