Metric Tire Sizes Confuse Me
Old 10-29-2009, 11:37 AM
audiomechanic's Avatar
audiomechanic
audiomechanic is offline
Here's a link to a Buckshot review which includes available sizes. I believe the stock 17" steel rims are 9" wide. Could be wrong but I think they're bigger than 8" wide.
Helps if I post the link: http://www.offroaders.com/tech/AT-MT...hot-Mudder.htm
EDIT 2: scratch the above. Helps if I scroll further down the chart. They do come in a 285X70R17. Doh.
So it's between the 305 and the 285. The 305 is very close to the 33X12.50 I am running now. The only difference I see is that the backspacing on the wheels would push them into the body, thus potentially creating clearance issues on the control arms. I suppose I need to measure the distance from the edge of the tire to the control arm at full lock, then measure the difference in back spacing between the stock rim and the Centerlines to determine if rubbing will be an issue.
Ugh.
Old 10-29-2009, 11:46 AM
Augiedoggy's Avatar
Augiedoggy
Augiedoggy is offline
Originally Posted by AlabamaRam95
those are some pretty good links.
this one is still my favorite.
http://www.1010tires.com/tiresizecalculator.asp
they are some of the first to come up when you google "tire conversion" or "tire calculator"
I used the miata one on monday to help answer a question in another thread...
when the rims stick out you actually have less clearence than stock rims as far as rubbing on the fender....its a tradeoff though as they might hit the frame/control arms.
Old 10-29-2009, 11:50 AM
Augiedoggy's Avatar
Augiedoggy
Ugh.
I believe you will be okay and have more clearence all around with the stock backspacing....I had 35" muddere on 9" rims with stock back spacing and just a body lift and (I think) 2500 springs in front and it cleared better than with my new 10"wide 4 " backspaced rims
Old 10-29-2009, 12:48 PM
audiomechanic
Nice! Well cool then!
Thanks, guys.
Old 10-29-2009, 01:48 PM
audiomechanic
Holy *****, Batman!!! The prices of tires have SKYROCKETED! When I bought my 33X12.50R15 Buckshots, they were about 600 for the set shipped. Now, that same set is almost 800 dollars! OUCH! WTF happened? Did Greenpeace get the government to infringe more taxes on tire companies?
Old 10-29-2009, 03:24 PM
Cereal Killer's Avatar
Cereal Killer
Cereal Killer is offline
Yeah, **** that. Buckshots were nice because they were cheap. If you're gonna pay $800 bucks for them get Super Swampers SSRs, or BFG Mud terrains.
Old 10-29-2009, 03:36 PM
audiomechanic
I never liked the look of SuperSwampers or noise level of them, but BFG's are worth considering. The tread pattern between the Buckshots and the MTs is very similar.
Quick Reply: Metric Tire Sizes Confuse Me
