Am i safe ? I need Help Asap...
Old Nov 9, 2009 | 10:09 PM
dodgeram2001's Avatar
dodgeram2001
Exclamation Am i safe ? I need Help Asap...
ok i just did spark plug wires and cap an rotor ok everything is perfect except that on the right side of where you screw the screw in it only went 3 fourths way in and now its stuck and it wont come out so everything is running smoothly but not sure if its safe or not i can barely move the cap up an down so will it be fine , and it did inprove my ruff idling .
Old Nov 9, 2009 | 10:18 PM
J415's Avatar
J415
You crossed the threads. Take it out how ever you can and just retap it. Then with a magnet, pick up the shavings so you don't mess anything else up. It needs to be fix, so better now then later. You should also consider double checking your post. Your grammars a bit off so it makes it harder to understand what your problem is.
Old Nov 9, 2009 | 10:19 PM
dodgeram2001
Dam ok There is just no room lol to do anything back there lol.
Old Nov 9, 2009 | 10:21 PM
MAJohns's Avatar
MAJohns
i agree
Old Nov 9, 2009 | 10:40 PM
Cereal Killer's Avatar
Cereal Killer
I'd fix it. I can see it causing a problem if you hit a bump or something, or possibly allowing water to get under it easier.
Better to just get it right and not have to worry.
Old Nov 9, 2009 | 10:44 PM
aim4squirrels's Avatar
aim4squirrels
If the cap is loose you can pop the rotor right off the disty and it'll fall sideways, short out, and melt. Then truck no makum go-fast. It can even happen right in the middle of trying to merge on the highway and getting up to speed, ask me how I know.
Old Nov 9, 2009 | 10:46 PM
dodgeram2001
i broke a screw driver tip just to try and get it out of there the screw its self errrr.
Old Nov 10, 2009 | 01:16 AM
011500Ram's Avatar
011500Ram
Your grammar is just as bad..
Old Nov 10, 2009 | 01:35 AM
Sheriff420's Avatar
Sheriff420
aim, how do you know?
any pictures of the results?
Old Nov 10, 2009 | 02:11 AM
dakotas ram's Avatar
dakotas ram
not quite
