What gap for 3923's?
Bigger wires, go stock gap, if you have a coil & ignition box, go .010 over.
When you install the plugs, put a piece of tape around the bottom of the socket closest to the ratchet. Mark a wide line with a sharpy to show which direction the gap opening points to. Put the plug into the socket so the gap lines up (as close as it will) with the line. Install the plug and if it lines up to roughly straight up leave it in, if the line is pointing down, pull the plug, try it in another cylinder later & try the next plug. Doing that can yield up to 2-3% improvement in power. Minor gain but it only takes time, will give smoother idle and very slight gain in mpg. FYI, you have just indexed your plugs
![Wink](https://dodgeforum.com/forum/images/smilies/wink.gif)
Trending Topics
