Best wheel/hub bearing?
Old Nov 19, 2009 | 02:35 AM
  #21
Sheriff420's Avatar
Sheriff420
max, you should go with Timken, i've always heard that they are the best.
aren't your axle seals still leaking? if they are then you should get those replaced when you replace the hubs.
Old Nov 19, 2009 | 10:12 AM
  #22
dodge15004x45.9's Avatar
dodge15004x45.9
No for some reason they stopped leaking.
Old Nov 19, 2009 | 10:23 AM
  #23
Sheriff420's Avatar
Sheriff420
thats probably because the front diff is so low on fluid that it isn't getting slung against the seal any more. which is bad.
Old Nov 19, 2009 | 07:47 PM
  #24
dodge15004x45.9
No there is fluid in there. It hasent leaked in a while. I hope I would have noticed it leaking like I did last time. When the end of my axle where soaked.
