My Rebuild Thread
Old Nov 16, 2009 | 09:35 AM
  #21
Sheriff420's Avatar
Sheriff420
25$ is pretty good for having someone else cut the runners off and polish/slightly bore the injector ports. it'll save you time so you can be doing one of the other repairs that the truck needs.
62$ is pretty steep for an oil change. i get a 5 quart jug of quaker state horsepower (synthetic) and a mopar filter for 25$ at walmart.
Old Nov 16, 2009 | 10:04 AM
  #22
95RAM360's Avatar
95RAM360
i took a Mobil 1 class for my job. so i know all the benifits, and prefer to use.
Mobil 1 Filter- 14.59
Lucus Synthetic Oil Stabilizer- 15.99
5 quart jug of Mobil 1 Synthetic Extended Performance 10w30- 26.00
then add tax.
its steep, but it will benifit in the long run
Old Nov 20, 2009 | 03:03 PM
  #23
95RAM360's Avatar
95RAM360
ok just got my intake back from gtting ported and polished. Tonight i will perform kegger mod...(my neighbor has a saw i can use instead of paying someone)
Tell me what you think....i cant wait till i get this together
New Intake Pic. 1
New Intake Pic. 2
I got the intake for free from my boss. (J415 clean out your mailbox ive been trying to get in touch with you.) and it cost me 40 bucks to get it to look like that.
Old Nov 20, 2009 | 04:50 PM
  #24
95RAM360's Avatar
95RAM360
heres an updated list
Plugs (From dealership)- 30bucks
EGR pipe&Gasket- 45.00
Dist.Cap/Rotor- 30.00
Intake Port and Polished- 40.00
Thermostat/Gasket- 11.00
Oil Changes- 135.00 (abouts)
Fixed Door & Rockers & Blemish on door- 60.00 (for dealer paint, clearcoat. bondo, sandpaper etc.)
Fuel injector o-rings set (x2)- 19.00
bringing my total to around 370.00 that ive spent so far. All i need to do is order Hughes plate, Mod my intake, 02 Sensor, and im ready to go. Im holding off on the cat for a little while, for im looking to move into a house right now, so money is kinda tight.
Old Nov 20, 2009 | 06:31 PM
  #25
PurplDodge's Avatar
PurplDodge
then add tax.
God, $15 for an oil filter? Napa Golds are just as good quality and are only $6.
You might wanna check this site out:
http://www.bobistheoilguy.com/forums...s.php?ubb=cfrm
....Oh yeah, I remember when I used to pay $60-$70 an oil change, then I joined BITOG Forums. I now spend $26....
Old Nov 20, 2009 | 07:42 PM
  #26
J415's Avatar
J415
Was it sponsored by Mobil 1 because that sounds kind of bias. I honestly would love for someone to explain why Mobil 1 is better then the rest...and where are you getting your mobil 1 filters from?! There $7 at walmart.
Old Nov 20, 2009 | 08:00 PM
  #27
95RAM360's Avatar
95RAM360
the wal-mart in my area does not carry them. (which is odd since i live in a big name city)
And the Mobil 1 class, they had visual demonstations with other synthetic oils, and then the Mobil 1. They used it on this little motor that would spin a dowel. then they would put weight on it, the other synthetics oils would make the dowel "seize" up after about 2-4 weights were put on (Penzoil, Castrol, Kendall, and Quaker State.) Then when the Mobil 1 was demonstated it was able to handle 6 of the weights, and was still going. the 7th made it "seize"
I guess that demonstates the "Under Load" and how it helps. There were other demonstations, but im not going to explain all of them...unless your interested
  #28
zman17's Avatar
zman17
Retired Moderator - RIP
I think he's sponsored by Lucas too! The Mobil1 is one thing, but geez with the Lucas hype already.
Old Nov 20, 2009 | 08:02 PM
  #29
95RAM360's Avatar
95RAM360
I love using the lucus lol
Old Nov 20, 2009 | 08:09 PM
  #30
J415's Avatar
J415
That "demonstration" sounds exactly like the slick 50 infomercial that was always on back in the 90's. Is that all your basing mobil 1's quality on? What else did they tell you?
