DIY: Orange Gear Indicator PRND21
If your tired of looking to see what gear your in and it shows reverse but your in neutral well if your orange indicator is off of were its supposed to be there is an easy fix, and it only takes a couple minutes
Before Pics
![Name: PA270033.jpg
Size: 75.2 KB](https://dodgeforum.com/forum/attachments/2nd-gen-ram-tech/96834d1501397675-diy-orange-gear-indicator-prnd21-pa270033.jpg)
![Name: PA270034.jpg
Size: 111.0 KB](https://dodgeforum.com/forum/attachments/2nd-gen-ram-tech/96835d1501397675-diy-orange-gear-indicator-prnd21-pa270034.jpg)
1. Take lower dash panel off, the one below the steering wheel
2. On the right side of the steering column you should see a tab sticking out that has a wire with a loop connected to it.
![Name: Fix.jpg
Size: 100.6 KB](https://dodgeforum.com/forum/attachments/2nd-gen-ram-tech/96836d1501397675-diy-orange-gear-indicator-prnd21-fix.jpg)
3. Right above this tab there is a plastic screw which you can adjust either way to adjust the indicator or just bend down the tab a tad
4. PUT PARKING BRAKE ON
5. Go through the gears and make sure its were you want it
6. Put dash panel back on
After Pics
![Name: PA270039.jpg
Size: 95.4 KB](https://dodgeforum.com/forum/attachments/2nd-gen-ram-tech/96837d1501397675-diy-orange-gear-indicator-prnd21-pa270039.jpg)
Before Pics
![Name: Fix.jpg
After Pics
![Name: PA270037.jpg
Size: 63.9 KB](https://dodgeforum.com/forum/attachments/2nd-gen-ram-tech/96838d1501397675-diy-orange-gear-indicator-prnd21-pa270037.jpg)
Trending Topics
