Let me run some numbers by yall
Old Nov 16, 2009 | 03:07 PM
dsertdog56's Avatar
dsertdog56
Originally Posted by HDRAMman
Do these seem bout right? Just wondering if my truck is performing the same as the others.
Avg. MPG 10.5 (live in Ohio so its fairly flat)
Top speed on flat ground 98?
What the quickest way to get a bit more out of my truck? The programers out there really do all that they claim they can? I.E. Hypertech's Power Programmer III claims a +21HP gain! ??
Pretty much sounds like my truck...unpowered, overweight, aerodynamics of a brick...with rounded corners . Except yours is faster (lucky bastage).
The fine print on the programer reads that you'll get this kind of gain only if you run premium gasoline with the tune. You'll have to decide if that's worth the extra cost.
Old Nov 16, 2009 | 03:16 PM
dodgeram07's Avatar
dodgeram07
gears,,,i see 33in tires
Old Nov 16, 2009 | 03:27 PM
Mowhawk's Avatar
Mowhawk
get some 4.10s if your running 33s
Old Nov 16, 2009 | 03:50 PM
lastrights's Avatar
lastrights
get a tuner
Old Nov 16, 2009 | 05:01 PM
redheadhunter21's Avatar
redheadhunter21
Look at the bright side I get 10ish with 2wd and almost stock sized tires but I can go a little faster all the way to the end of the speedo, I can get to 100 no problem
Old Nov 16, 2009 | 07:54 PM
J415's Avatar
J415
Originally Posted by VWandDodge
Why is it guys who drive a V8 4x4 are always asking how to get better mileage? Take my advice -- buy a little 4-banger for daily driving. That's the best way to increase your mileage.
...because that extra diff is lowering their MPG's severely. 4 bangers are the way to go if you want good mileage. Or you can get a skateboard and just use your feet like Fred Flinstone.
Old Nov 16, 2009 | 08:10 PM
silverbullet-dodgeram's Avatar
mpg sounds bout right but 98mph not so mine will do 112 and Ive hit 1just shy of 120 like 119 the be technical (on a long hill tho lol)
Old Nov 16, 2009 | 08:30 PM
notanexit7's Avatar
notanexit7
I only get about 10 with my 2wd but that's only because I tow about 7k pounds every weekend
Old Nov 16, 2009 | 08:42 PM
nathangfnd's Avatar
nathangfnd
on flat ground kinda bumpy but not down hill i got mine up to 108 with just hardland sharps and K&N . now with my superchips same road i got to 115.
And i have blown plenum and 35s with stock gears.
But it also depends on how well you take care of your truck. mine always gets its oil changed on time and all.
Old Nov 16, 2009 | 09:10 PM
VEETEN's Avatar
VEETEN
I did about 85-90MPH driving down here, when I moved down here. but man If i hit a pebble the wrong way going that fast I gotta fight to keep her on the road...LOL
You guys are nuts.
But that's why I'm here too.....
