truck doesnt shift into overdrive
Old Nov 16, 2009 | 05:38 PM
townsley4's Avatar
townsley4
Default truck doesnt shift into overdrive
hey, so the last couple of days i have been noticing my truck has a hard time shifting from 2nd to 3rd and it doesnt want to shift into overdrive. i had to go like 40mph all the way home because i couldnt get it to shift. finally it did after messing around with the o/d button. and also it is realy sluggish on accleration. i dont know whats going on here. i thougth the exhaust was clogged, but there seems to be a pretty good amount of pressure coming out. any ideas?
Old Nov 16, 2009 | 05:49 PM
95RAM360's Avatar
95RAM360
5.9, or 5.2? how many miles? has transmission been replaced? is there ATF+4 in it? has it been flushed/new filter. have you had the bands adjusted?
Old Nov 16, 2009 | 05:53 PM
townsley4's Avatar
townsley4
5.2, 120k miles. tranny has never been replaced that i know of. idk what atf+4 is..and i doubt it. but it has had the the governor worked on.
Old Nov 16, 2009 | 06:09 PM
Hammer Down's Avatar
Hammer Down
atf+4 is the automatic transmission fluid recommended for our trucks and most modern autos. You should have it.
on another note, Let me ask a stupid question. Have you checked the fluid level?
Old Nov 16, 2009 | 06:14 PM
townsley4's Avatar
townsley4
yea, its where it should be. my garage is pretty level soo..it should be right. it is pink, it doesnt smell to bad...it smells like...b.o. but i think the fluid is ok.
Old Nov 16, 2009 | 07:01 PM
Hammer Down
It sounds like an electrical issue until you mentioned the sluggishness. Check out the throttle cable that runs from the throttle body to the transmission. You may also want to consider a fluid change and maybe a band adjustment.
One more thing, your transmission has oulived most by a long shot. I hope it isn't in its death throws, but it is possible.
Old Nov 16, 2009 | 07:29 PM
townsley4's Avatar
townsley4
i hope not. i need my truck everyday. i live 45 mins away from the college im attending that i have to drive everyday. hopefully its something minor. as for the sluggish acceleration, it might be the plenum. but i notice the engine is loud when its idling. like airy sound.
Old Nov 16, 2009 | 07:55 PM
Hammer Down
It could very well be a vacum problem to explain your lack of power. This could also be part of your shifting problem. If you're not getting any power, the truck's computer will sense that the engine is straining (as if you're climbing a hill) and the transmission wants to keep a lower gear to give you more torque. Just an idea.
Old Nov 16, 2009 | 07:56 PM
VEETEN's Avatar
VEETEN
Do you have a CAT or is it gutted, there is a diy up top on checking these with a IR temp gun, don't rely on just holding you're hand in front of the pipe
https://dodgeforum.com/forum/2nd-gen...e-ram-faq.html
Old Nov 16, 2009 | 08:17 PM
Hammer Down
That could be part of the problem. A cat at operating temperature should be hotter downstream than upstream.
