New problem on the way to the tire shop help ASAP
Old Nov 22, 2009 | 03:09 PM
Jersey Anthony's Avatar
Jersey Anthony
Default Possible U Joint failure, need opinions asap
Hey guys,
So on my way to the tire shop to get my new 33'' m/t and my new water pump my truck made like a jerk and clunk noise. After that it would drive and sound fine while i had my foot on the gas but when i took my foot off it made like a clunk, clunk, clunk clunk, and kept going until i hit the gas again. After I let off the gas it would do it again. I looked under the truck and didnt see anything rubbing on the drive shaft, or anything out of ordinary. The trans didnt slip at all, and no warning lights have come on. Any ideas.
Thanks anthony
btw the truck has 200k on it. Rebuilt motor like 40k ago. Trans recently had flush and new filter and fluid still ruby red and smells fine.
Old Nov 22, 2009 | 03:40 PM
95RAM360's Avatar
95RAM360
sounds like a u-joint to me
check to see if they all have their pins still in them.
Old Nov 22, 2009 | 11:27 PM
Jersey Anthony
i'll check that tommrow thanks, is the u joint swap tough?
Old Nov 22, 2009 | 11:50 PM
dakotas ram's Avatar
dakotas ram
please use more descriptive titles
Old Nov 23, 2009 | 12:49 AM
Rob O's Avatar
Rob O
Dont want to scare you but my truck made that same noise only on decel and it was the pinion grinding its self to mush which it did so check for play and the end of the driveshaft if it moves if your lucky you can just replace the rear pinon seal and the pinion bearing. if your not lucky like myself you need to rebuild your rear. hope for the best but possible the ujoints also so check them for some play
Old Nov 23, 2009 | 05:59 AM
95RAM360's Avatar
95RAM360
u-joints...its hard to say, some think its tough, some dont...ive done the u-joints in the garage i work at so i had an advantage, and it was easy cuz my boss helped me
Old Nov 23, 2009 | 10:16 AM
Sheriff420's Avatar
Sheriff420
u joints are easy on a 1500 (which is what most of us have on here).
don't know the difficulty level on a 2500. i've heard that your hubs/rotors can be quite a pain if you have a rust issue.
Old Nov 23, 2009 | 01:58 PM
dodgeboy1979's Avatar
dodgeboy1979
the u-joints on the 2500 are easy too. Just get a ball joint press is what i found is the easiest to remove and replace the new u-joints.
