Lets see your intake!
Old Dec 2, 2010 | 07:08 PM
  #91
RamSport97's Avatar
RamSport97
Always crack up when I see Zman's redneck engineering intake!!
I changed things up a little, went the Silver Dodge route.
Old Dec 2, 2010 | 10:27 PM
  #92
hutch311's Avatar
hutch311
zman has the best intake ive evar seen!
Old Dec 3, 2010 | 12:24 AM
  #93
RM_Indy's Avatar
RM_Indy
Thanks Zman! Almost pissed myself!
To those that say the 14x3 lost torque, I find that hard to believe.
First mod I did to my stock Indy was the original K&N FIPK
Thats a chrome top 14" with a 2.25" tall K&N filter.
First day at the dragstrip with my Indy was July 8/96, she had 1200miles on her.
2 other identical Indys there, we all had 3.55 lsd rear ends & factory roll pans.
Only other things I had was a 125lb f/g matching tonneau & the K&N.
Neither of the 2 Indys could keep up with me off the line.
Every time we raced I had them by .3 seconds, none of us had been down 1/4m before.
Originally Posted by Eric99ram
It works fine with mine. I'm running the mopar 12x3 intake and I'm using the fastmans s bolt but I could only twist in like 3-4 threads at most in order to be able to put the wing nut on. Just happy that it comes with a nut to hold it in place.
Oh Indy, what efan setup are you running? Does the rad overflow tank mount to it and what did you do with your windshield washer fluid tank?
Sorry didnt see this when you posted way back
I made a long S bolt when I had 360 w/52 Fastman on it, bolt not long enough IMHO even with lock nut.
Those are the Flex a lite 210B fans, also available in red, yellow & black.
Only rated for 2500 cfm yet have kept my Indy cool even with 510hp (mild 360/7psi-ran 12.9 with)
The overflow I zip tied to rad, wiper resevoir? Whats that lol
They are over rated, havent had wipers on it since 00, removed linkage & mtr shortly after adding the fans.
You can leave enough of the shroud to mount both overflow & wiper resevior.
Cut out the rest & you can still get in & work on the motor standing between fans/pulleys
Old Dec 3, 2010 | 02:10 AM
  #94
97ramlv's Avatar
97ramlv
How did you put 1 ton brakes?
Old Dec 3, 2010 | 02:26 PM
  #95
Mr-Sleeper-34's Avatar
Mr-Sleeper-34
Originally Posted by dodgeram07
^Where can I pick this intake system up from? PM me.
Originally Posted by Pacmanloads
hahahahahahahahahahahahahahahahahahaha ! Unreal !
^Wow. That Zman system is a little much *blank stare O_o*
Old Dec 3, 2010 | 03:54 PM
  #96
zman17's Avatar
zman17
Retired Moderator - RIP
That intake took care of the lean I had on the driver side too. The heck with new springs.
Old May 4, 2011 | 07:28 PM
  #97
dodgeman2289's Avatar
dodgeman2289
i want to get one of those cirlce old school round air cleaners.. wut is the best to get that doesnt require a s-bolt???
Old May 4, 2011 | 07:48 PM
  #98
J415's Avatar
J415
I'm almost positive they all require an s-bolt.
Old May 4, 2011 | 09:16 PM
  #99
dodgeman2289
wut are the sizes that will fit are throttle bodys??? im looking at one with this...
Carburetor Neck/Air Horn Diameter:5.125 inDiameter:9 inDropped Distance:1.5 inFinish:CHROME Height:2 inHousing Material:STEEL Shape:ROUND
Old May 4, 2011 | 09:21 PM
  #100
CappinHoff's Avatar
CappinHoff
None fit the throttle body, you have to buy an adapter.
